Old 09-19-2006, 07:32 AM
Jerry Clayton's Avatar
To make a simple jig to cut the tubes--use a square piece just oversize of the header tube size--weld on a piece to clamp the curved piece--cut lengthwise thru the curve with a saw, turn over 90* and cut second side--they all should fit together perfectly--practice on mild steel, stainless is $$$$$
Cut back the joined end to the diameter you want, you will probably want to pretrim so the tig torch will fit in the opening
I've started just buying mine from down in Nascar land!!!
Jerry
Old 09-21-2006, 06:06 AM
Gav's Avatar
Gav Gav is offline
Wind the wick up on the vortec and the gases WILL get out somewhere high flow cats or not!!
Old 04-11-2007, 10:41 PM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Well the Cobras been on the back burner for a while but I am now back into it with a vengeance here are a few pics off the collectors that we have fabricated they are 2" primaries into 3 1/2" that will step up to a 4 1/2 pipe
Craig W
Central Coast NSW
Old 04-11-2007, 11:28 PM
CHANMADD's Avatar
Nice job! Those should flow very nicely.
Old 04-11-2007, 11:42 PM
Mando's Avatar
$hit, they look fantastic
REGARDS.
Mando
Old 04-12-2007, 04:29 AM
Default RE: Side pipes
Hi guys
Don't mean to butt in but on this topic I just thought you might like to see the workmanship of the guys at Liverpool Exhausts who made up the exhaust system for my GT40.
Given the limited amount of room they had to work with they did a great job and made these to my exact specifications and requirements.
Full stainless steel and ceramic coated.
Dimi
Old 04-12-2007, 05:36 PM
Nice pipes!
A BOSS in a GT40 - cool!
Old 04-12-2007, 07:11 PM
Aussie Mike's Avatar
Welcome to the Forum Dimi. Nice setup you've got there. How did you go getting it through the noise tests?
Mike Murphy
Melbourne Australia
Old 04-12-2007, 08:21 PM
Dwight's Avatar
Smile
Thanks, side pipes will be my next big upgrade project.
Dwight
Old 04-12-2007, 08:49 PM
RedCSX1's Avatar
Default Beautiful work
Just awesome fabrication
Morgan LeBlanc
Fresno CA
Old 04-13-2007, 06:58 AM
Dimi,
Clearly I went to the wrong people.
Nice work, mind if I ask how much? PM me if required.
Beejay
Old 04-14-2007, 08:50 PM
Cobra Make, Engine: Scratch build
Nice small Cats, what are they from?
  #33 (permalink)
Old 04-15-2007, 08:38 AM
Default RE; Small cats
Hi
Not sure what the cats were but they are stainless and were shortened to fit into the available space.
Oxy sensors were also fitted into the cats both before and after as per the stock Boss engine setup.
Dimi
  #34 (permalink)
Old 04-15-2007, 02:38 PM
Cobra.au's Avatar
They look like metalcats to me.
Craig W
Central Coast NSW
