Old 09-14-2006, 07:11 AM
Tony Cram's Avatar
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Default Speedo Calibration
Need help!!!
Just finishing off the car for the Nationals and replaced the speedo cable as it was noisey. Thought I would be smart and get the Speedo re calibrated since I have put 295/60/15's on the rear a few months back. I know the speedo was out by about 10 K's fast.
Took speedo to Ringwood speedo's and wow I can now do 150K's at about 2000 revs. It looks like it's out by about 50K's now.
I have 3.31 jag diff, Ford toploader (Speedo gear on cable is 16 Tooth) and I know I should be doing about 2600RPM at 100K/Hr.
I gave them the Revs/km for 295's which is 484, the diff ratio and the gearbox type. I asked if they needed anything else and as they did not ask for anymore information I assumed they would have the rest and be able to calibrate correctly.
Can someone help please....????? before I ring them and get them to re calibrate.
Old 09-16-2006, 03:18 PM
BMK's Avatar
BMK BMK is offline
I have used the VDO distributors in Heidelberg. They are very helpful and can do it with you.
They have a measured kilometre and use GPS gear as well.
Roger Howard at Howard instruments is the guy to talk with. If he asks tell him I gave you his name. Mmmm - my commission...
Bernie Knight
