Old 11-09-2006, 03:02 PM
Cobra Make, Engine: CR 3205
Default Cold air in take for CR
Hi guys , this is an one easy way to build yourself a cold air in take for your Classic Revival.
Name:  air intake small copy.jpg
Name:  air intake 3 copy.jpg
Name:  air intake2 copy.jpg
Name:  air intake1 copy.jpg
One tip make sure that the front wheel doesnt fowl on full lock or when the wheel is at full bump.
Old 11-09-2006, 05:40 PM
Looks good.
Any other car pics?
Ben
Old 11-09-2006, 09:10 PM
Aussie Mike's Avatar
Nice work.
Did you make the duct yourself?
Mike Murphy
Melbourne Australia
Old 11-10-2006, 10:27 PM
What type of filter are you using in the duct?
See attached pic our cold air intake through the scoop.
Ian
Old 11-10-2006, 11:22 PM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Ian
opps what pic
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 11-11-2006, 12:03 AM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Just something to note: The bonnet scoop will not flow enough air for forced induction so the brake duct might even starve a N/A engine.
Just some info that I learned the hard way.
Craig W
Central Coast NSW
Old 11-12-2006, 05:33 PM
pneall's Avatar
Slow427,
Wish I saw those before I bought my brake cooling ducts
Craig is probably right . You wil be OK if you are using one from each side though.
Regards,
Phil
Old 11-13-2006, 03:15 AM
Default Air in take
Phil im using 100 mm ID hose and both in takes are being used.
They should flow very well.
Here's hope
