Old 02-21-2007, 01:13 PM
hsv300's Avatar
Default Maf
Does any one know if the Mass Airflow Meter on an Aust 5.4l can be used on a US 4.6l???
Harrison Cobra
Ford 4.6l supercharged
T56 six speed
Old 02-21-2007, 03:16 PM
Blair's Avatar
Cobra Make, Engine: DRB Cobra, Ford 2001 4.6l Quad Cam Stroked to 5.2l (ported heads, reground cams from SHM + a Kenne Bell 2.8 Charger + Intercooler) Autronic SM4 Ecu, Autometer Cobalt Gauges, Trigo 8 & 10 x 15 Halibrand Knock Offs, Goodyear Eagle Tyres
Hmmmm
I've got a heap of articles for you! PM me your email address and I'll send you so much Mass Air Flow information you'll wish you never asked.
Never Piss into the Wind!
Old 02-21-2007, 05:28 PM
hsv300's Avatar
PM sent Blair
Harrison Cobra
T56 six speed
Old 02-21-2007, 05:30 PM
Cobra Make, Engine: Classic Revival, Supercharged 99/01 4.6L DOHC Ford V8 T56 6 speed 18" wheels
Thumbs up Maf
I am not 100% sure what size MAF the BA 5.4L runs, I am guessing 90mm. I know the 2003 supercharged 4.6L runs a 90mm both should be Bosch units. The naturally aspirated 99/01 4.6L DOHC engines run a 76mm unit. Only last week I bought a New 90mm MAF and injectors off a 2003 Supercharged 4.6L off Ebay in the States for less than what a 90mm MAF goes for here. There seems to be plenty available over there. I'd stick with what the engine came with. It is easier to troubleshoot if the engine won't start.
I am not sure if you received my request before the server crashed, in case you didn't, would you be able to measure your supercharger crankshaft pulley and the supercharger pully. I need to know the standard ratio between the two. Thanks
Old 02-21-2007, 06:24 PM
hsv300's Avatar
66reno The sizes are supercharger pulley 95mm and crankshaft pulley 190mm Diameter give or take a few mill. Can you pm me the link on Ebay??
Harrison Cobra
T56 six speed
Old 02-22-2007, 08:42 PM
hsv300's Avatar
Just worked out i don't need a mass air flow meter Uses throttle postion sensors. Looks like I save save money at last
Harrison Cobra
T56 six speed
Rate This Thread:
