Old 03-08-2007, 02:52 PM
Cobra Make, Engine: Harrison Ford 4.6 DOHC, 5 speed gearbox
Default Hodson
The decision making process is finally coming to an end. I am going to go the way of a partial build (approx 80%) by G force and then finish off the last section myself. I am looking at putting a 4.6 all alloy 32 valve DOHC engine in which needs to be post 2003. I have found a new engine but the seller cannot tell me the build date. does anyone know how to tell the build date from the numbers stamped on the engine? I am also looking at matching a Tremec 5 speed gear box to it. Does anyone know of any problems matching this gearbox / bell housing to the 4.6.
thanks guys from the addicted one
Old 03-08-2007, 03:38 PM
hsv300's Avatar
my supercharged 4.6 has a sticker on the right tapet cover when looking from the front 7/23/03 if that helps Think you will need a U.S. gearbox or bell housing?
Harrison Cobra
Ford 4.6l supercharged
T56 six speed
Old 03-08-2007, 04:04 PM
Cobra Make, Engine: Classic Revival, Supercharged 99/01 4.6L DOHC Ford V8 T56 6 speed 18" wheels
Ford actually went to a cast iron block in 2003 with aluminium heads. I am not entirely sure if it was only for the supercharged engines though and whether the naturally aspirated are still aluminium. I'd have to check with the info I have at home to be sure.
Old 03-10-2007, 04:35 AM
Doesn't Rod Hadfield ...Castlemaine Rod Shop.. make bell housings for the adaption ? Give him a try.
Smithy
Old 03-10-2007, 01:07 PM
Blair's Avatar
Cobra Make, Engine: DRB Cobra, Ford 2001 4.6l Quad Cam Stroked to 5.2l (ported heads, reground cams from SHM + a Kenne Bell 2.8 Charger + Intercooler) Autronic SM4 Ecu, Autometer Cobalt Gauges, Trigo 8 & 10 x 15 Halibrand Knock Offs, Goodyear Eagle Tyres
Hodson I drove through Townsville yesterday and thought about you. Good to see I'll have another Cobra to hang with up here. Seeing that engine is Euro 3 (meaning it will have to be registered before the end of the year) we'll be cruising together quicker then you think!
Never Piss into the Wind!
Old 03-10-2007, 02:22 PM
Hodson, If you require a SFI tested bellhousing for the 4.6 mated to a tremec see here:
http://www.quicktimeinc.com/products.html
Much lighter than the hydro formed bellhousings.
