Old 03-21-2007, 12:21 AM
Aussie Mike's Avatar
To quote Yoda regarding the Sith "Always two there are; no more, no less: a master and an apprentice."
Mike Murphy
Melbourne Australia
Old 03-21-2007, 12:51 AM
Some of my favourite tools:
An 8" grinder with a belt linisher attachment on the end. I use a fine stone on the other end for sharpening tool steel for the lathe. The belt linisher id great for shaping parts and cleaning up welds or preping parts for welding. You can get a variety of belts in different grits. I also use scotchbrite belts for prepping parts for polishing.
Another favorite is a 6" grinder with a taper on one end to hold polishing mops and a whire wheel on the other end. Metal polishing is actually quite easy and reasonably inexpensive once you get set up and learn the basic techniques. The wire wheel is great for cleaning threads on bolts and other stubborn cleaning jobs. I probably should buy an 8" grinder to use as a buff but the 6" works OK. An 8" buff would probably just throw the parts further across the shed when it grabs an edge.
Both grinder an buffer are mounted on pedestals that I welded up. This gives you plenty of room to work around them. When they are mounted on a bench they chew up valuable bench space and make a mess.
As Leeroy mentioned the Nutsert tool is a must have. They make for a very professional finish and a reliable stress free fixing into fiberglass.
Get your self a little rool around gas lift stool. It'll save your back and knees when working down low on the car. They usually have a handy tray in the bottom to hold your tools.
Mike Murphy
Melbourne Australia
Old 03-21-2007, 12:57 AM
I took the site down a while back Les. When I get some free time I'll put up a revised and improved version. There are so many more Darkside cars now.
Mike Murphy
Melbourne Australia
Blair's Avatar
Cobra Make, Engine: DRB Cobra, Ford 2001 4.6l Quad Cam Stroked to 5.2l (ported heads, reground cams from SHM + a Kenne Bell 2.8 Charger + Intercooler) Autronic SM4 Ecu, Autometer Cobalt Gauges, Trigo 8 & 10 x 15 Halibrand Knock Offs, Goodyear Eagle Tyres
Remember Yoda drives for FORD! He ain't a part of the Dark Side!
Never Piss into the Wind!
Old 03-21-2007, 04:00 PM
boxhead's Avatar
I bought a office chair at an auction for $1.00 that I use in my shed for working.
I have a 6 inch bench grinder with fine stone on one end and wire wheel on the other, I also have an 8 inch bench grinder that has course stone and polishing wheel on the ends.
I allready had a very comprehensive tool kit (ex tech) must haves include the basic spanners, sockets and screwdrivers, I also have a good quality wire crimping kit (caterpillar), a good quality multimeter (fluke), Large & small soldering iron, The nutsert tool is a must have.
I also have a large solid bench mounted to the wall and floor, with a vice at each end and room to move.
Cordless drill, jigsaw, angle grinder, jack & stands, plenty of lights in the roof and a lead light, mig welder, Fridge and radio. [IMG][/IMG]
I am sure there are others that I have forgotten.
I dont have a floor creeper, Instead I bought some old carpet and have laid it down on the ground, my feet dont get sore after standing in the shed looking at cars and it is easier to crawl under the car for a sleep.
Cruising in 5th
Old 03-21-2007, 04:07 PM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
I must also give my thumbs up for the nutsert tool, and the roll around seats. They really do save your legs and knees.
I can also give massive thumbs up the Magic Fridge (hic) and a Tele to watch any motor sport event that happens to be on when you are playi.. oops... working in the shed
Old 03-21-2007, 07:12 PM
Cobra Make, Engine: Classic Revival (CR3204) 6ltr s/c, T56 6spd
I'll give another vote for the threaded nutsert tool.
Also if you're planning to use donor car parts, a grinder (or electric drill) with a wire brush attchment is a must for cleaning up the parts.
Old 03-21-2007, 07:19 PM
sambo's Avatar
I've googled these nutsert tools and turned up nothing locally. Is it an attachment for a standard riveter or a separate tool by itself? Good place to buy one? If it's Bunnings then sorry for asking the obvious! Thanks.
Old 03-21-2007, 07:42 PM
Hi Sambo,
I can't remember the actual brand of my nutsert tool. Also nutsert seems to more of an industry term..try using 'threaded insert'.
I've also just done a quick search on the RS webpage and found this one.
RS Australia Threaded Insert Toolkit
There are quite a few variations but they all achieve the same outcome. My kit came with the attachments to do 4, 5 and 6mm threaded inserts. An 8mm insert would also be useful.
All the best,
Luke......
Old 03-21-2007, 07:52 PM
David Hodgson's Avatar
Nutsert is actually the brand name of the ones I had.
I made an 8mm tool out of an old pop rivet gun, though I had to be carefull with it as it did not have the right anvil shape.
Be aware nutserts come in varying depths for thin or thick sheet applications, also in steel or alloy.
SLIPRY
Old 03-21-2007, 08:09 PM
boxhead's Avatar
This is where I got mine from, http://www.normist.com.au/index.php
When I get home tonight I will get a Brand name
Here is a pic of it.
[IMG][/IMG]
Cruising in 5th
Old 03-21-2007, 08:36 PM
sambo's Avatar
Brilliant guys, thanks.
Old 03-21-2007, 09:27 PM
I've got a nutsert kit made by Teng Tools. Part Number:TTNR81
It works great. Here's a link to the Teng Tools catalogue: Teng Tools Catalogue
Mike Murphy
Melbourne Australia
Old 03-21-2007, 10:11 PM
John-Tucson's Avatar
How can you guys talk about a nutsert with all of that beer sitting in the frig ????
John
Old 03-21-2007, 10:32 PM
Crown Largers too. I suspect that picture was taken very shortly after placing those beers in there. I also think the reason they were still in there at the time of the picture was that they weren't yet cold enough to drink.
Mike Murphy
Melbourne Australia
Old 03-21-2007, 10:40 PM
That's just the appetisers. I'll bet there is bathtub full of Darwin Stubbies out the back for the real drink ...
Old 03-21-2007, 10:25 PM
sambo's Avatar
"All that beer"?? That's barely enough to whet the lips down here.
Old 03-21-2007, 10:43 PM
You guys are great ! Hopefully one of these years I'll be able to join you for a beer and learn what a nutsert is.
John
Old 03-21-2007, 11:35 PM
John, you are most welcome to join us for a few refreshing beverages.
Mike Murphy
Melbourne Australia
Old 03-21-2007, 11:40 PM
boxhead's Avatar
Mike,
You hit the nail on the head, the fridge has had many more beers (and beams and scotchs) cycle through it since those pictures.
There arent too many crownies in there lately, more XXXX Gold.
I can dring afew more of the golds before I drive my VW around the motoX tracks.
[IMG][/IMG]
I better get some more pics, it now has the stars on the flag, the numbers on the doors and the name on the roof.
Cruising in 5th
Rate This Thread:
