Old 04-09-2007, 11:05 PM
Default LS1 Fuel system and Wiring Diagram
Help Can someone provide me with a wiring diagram and fuel system diagram for a 2004 LS1. I see from an old thread there have been PDF files floating around.
Old 04-10-2007, 04:55 PM
cobbindale's Avatar
Cobra Make, Engine: Classic Revival.
Macloft,
Have sent PM,
Cheers, Dale.
Old 04-10-2007, 08:16 PM
boxhead's Avatar
Ya beat me to it Dale.
Cruising in 5th
Old 04-10-2007, 08:43 PM
sambo's Avatar
Are these LS1 systems similar to L76/LS2 engines? If so, can someone please PM me too?!
Old 04-11-2007, 12:38 AM
nope ls2 is totally different
Old 04-11-2007, 03:23 AM
boxhead's Avatar
I will see what I can get for you Sambo.
Unless you have easy access to it Sideshow?
I no longer work at the Holden Dealership so I cant just go and get it anymore.
Cruising in 5th
Old 04-11-2007, 05:04 AM
sambo's Avatar
No worries fellas, just curious. I know the pin-outs etc will have changed, but when you have zero knowledge about these things anything helps.
Old 04-11-2007, 05:08 AM
Cobra Make, Engine: Classic Revival (CR3204) 6ltr s/c, T56 6spd
If its not too much trouble, can I also get a copy of this info??
All the best,
Luke.....
Old 04-11-2007, 05:26 AM
PCC's Avatar
PCC PCC is offline
Mac,
How's the build going - did you pick up the Harrison?
I'm hopefully getting down to the Cleveland Autospectacular later in the month (I have a certain trophy to regain). If you're passing shout out (I'm a bugger for forgetting a face) and we'll have a yarn
PCC (Peter Craig)
Keep the sun shining
Old 04-11-2007, 02:25 PM
Builds going great Everything is fitting well. Cant get over how straight the body is
The suspension/brakes in place. Motor/ gearbox is going in. Currently working on the fuel system and sorting the harness routing.
Old 04-11-2007, 04:50 PM
sorry but i do wiring for a living so unfortunately i dont hand anyhting out
if you sned me the loom i can wire it up with relays and whatever is needed
to suit your application for a fee
as i said in another post the very late model ls1 and ls2 depending on where it was bought might comne with missing parts
like a new ls1 from holden wont have o2 sensors
ls1 fly by wire from wreckers wont have pedal sensor plug
id say ls2 is same
holden has told me to get everything u need to get everything working
on an ls2 u need 2 or 3 looms engine body and not sure what 3rd one was
im slowly buying in the small missing parts or plugs so at the end u dont have to buy a whole extra loom
as i get stuff in i put them on my website and soon will have newsletter to subsrcibers which will show new parts
im working up at newcastle for 2 days now when i get back if u want i will do a write up and diagram for setting fuel system up
thanks
jim
Old 04-11-2007, 05:07 PM
sambo's Avatar
Thanks Jim, that would be a great help for anyone in the build phase at the moment. Perhaps put your website into your profile or post it again here - I couldn't find it after a quick search of the forum! Cheers.
Edit: Found it. http://spw.starkie.net
Old 04-14-2007, 05:39 AM
got a call about ls2 plugs
just for those who dont know
the ls2 6lt has 3 main wiring looms
one is on the engine and engine ecu and auto ecu and auto
one is from engine ecu to power and other stuff
and one goes to other stuff and pedal sensor i think
when u get ls2 u just get the main loom
i think price to buy the other 2 looms will reach maybe 1000 bucks or more
anyway i hope to get available parts to make the loom which goes on ecu and pedal and have left over wires for power etc
will keep u all posted it wont be cheap but will be much cheaper than buying looms from holden
i think maybe people should start doin research before jumpin to far into deep
end with the very late model engines
as i just got an ls1 fly by wire goin and stupid factory holden diagrams were wrong but now i have my own modified ones to do the others abit quicker i hope heheeh
my website
www.sideshowsperformancewiring.com.au
Old 04-14-2007, 06:16 PM
boxhead's Avatar
For those that need it I have a printed version of the LS1 engine wiring (VT2 & VX1) and a printed version of the LS2 wiring (VX2 & VY1).
Pm me a fax number and I will shoot it through.
Also I tried to get the L76 but found the programme very difficult to follow, ie click here for this, click here for that.
There was no overall diagram, but the VE (L76) workshop manual should be available from your local Holden dealer, the dealer I used to work at tried to source a part number for me but it was not listed yet, they said that best thing to do would be to get your local dealer (where your going to purchase from) to contact Holden parts help desk - they only work weekdays.
Cruising in 5th
