questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
04-30-2007, 12:17 AM
custom aluminium
hey guys my names shaun mellish im new to the forum. I own my own buisness doing alloy fabrication and welding. You most prob have seen my work on phil mizzys,phil neals, and few other cars. I build radiators, intercoolers and piping, turbo and inlet manifolds, fuel tanks catch cans, etc, il have a website soon il let you guys know. Also in the process of designing my own sheetmetal inlet manifold for the ls1 if any interest.
Advertising
04-30-2007, 12:58 AM
nsw
Cobra Make, Engine: CR 3205
Hi Shaun, its Paul here you had made a swirl pot for me and may i say your work is AMAZING.
Guys Shauns work is fantastic ask anyone on this forum and his prices are very good too.
Keep up the good work
Paul
04-30-2007, 01:03 AM
Cobra Make, Engine: Some Backyardy ****box
Welcome to the forum Shaun!
As Paul has stated your work is amazing, I should know a lot of it is under Phils bonnet
04-30-2007, 04:01 AM
Zzz
Shaun
welcome to the forum. Look forward to your site.
Mmmm aluminium work, I have some also....
Bernie Knight
04-30-2007, 05:03 PM
NS
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Hi Shaun
I would like to talk to you about making a fuel tank for my Cobra can you PM me your phone number
Craig W
Central Coast NSW
04-30-2007, 07:17 PM
hi graig my no. is 0404295199.
04-30-2007, 08:04 PM
VIC
Where are you located Shaun?
04-30-2007, 08:47 PM
in catherinefields its 5min out of narrellan.
04-30-2007, 08:49 PM
04-30-2007, 10:01 PM
NT
Hi there Shaun,
I will be wanting to get a fuel tank and radiator filler/expansion tank made soon.
I want to use the standard VN type in tank pump and pickp,and the sender unit is a VDO style that is fitted through a hole in the top of the tank.
My car is a CR so something similar in design and fitting to Phil Neals would be great.
I can post you the pickup and sender unit.
And in regards to the radiator tank I am open to suggestions regarding size and shape, I would like it to sit infront of the l/h shock tower, inside the engine bay, infront of the X brace. If you sorta know what I am saying?
Regards,
Cruising in 5th
05-01-2007, 12:16 AM
NSW
 5 mimutes on the forums and he's already two weeks behind in work
When can you fit me in ?
05-01-2007, 12:28 AM
NSW
Boxhead,
Shaun made up something like that for Paul.
I went for a tank on the firewall, will post pics when it is polished.
Ben
05-01-2007, 12:44 AM
Zzz
acecob
Wait until he 'Posts' on the Hotrod and Bike forums..
Bernie Knight
05-01-2007, 01:53 AM
NSW
when you think about it , it's a great way to advertise
05-01-2007, 06:12 AM
box head i do have measurements for the radiator. if you give me a call tomorrow i can fax them through, 4 a header tank i can do 1 like i did 4 luke gillett they look great. if u had something else in mind let me know tomorrow fuel tank is fine if its the same chasis as phils il work it out. would rather use external pump setup. but if you are happy with internal thats ok.
05-01-2007, 04:25 PM
NT
Thanks Shaun,
I am not after a radiator just yet (soon).
But I do need a header tank, I just had a look in Lukes gallery, and yes that is the type and style tank I am after.
Can you tell me the dimensions of the tank and the pipe locations, in relation to the height from bottom of tank.
In regard to the fuel tank, it isnt imperative that I have an in tank pump setup, It is just that I do have a pickup and new pump here (can always sell the pump)
My car uses the standard VT fuel pump that is located inside a swirl pot.
So I need a pump that will transfer fuel from main tank into swirl pot.
The sender unit is specific to the gauges though, so it must use the sender I have.
Cruising in 5th
05-01-2007, 08:06 PM
NSW
Top Quality
Guys if you want top work done Shaun can do it.He has done a stack of my alloy work and its always top quality.
Check out Phil M's posts to see the type of work Shaun can do.
Welcome aboard Shaun
Phil
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
