Old 05-04-2007, 05:20 AM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Default Fuel tank leaking
Well when I got home tonight and went into the garage the floor was covered in petrol and it was pouring out of the Cobra.
I don't know what would cause a catastrophic leak as there was no sign of a leak yesterday and the Cobra hasn't moved for a couple of weeks.
As the tank is in the boot above the dif it will be a difficult job to get to it to examine where it is leaking from.
That will be a job for tomorrow.
Bryan
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 05-04-2007, 05:54 AM
Brian, make sure you hook the car to an earth. Plastic bodies make static electricity.
Sounds like a bugga of a job.
Old 05-04-2007, 10:05 AM
Clois Harlan's Avatar
Brian I went through this same problem last summer. As it turned out my vent had became clogged and the tank was under a vacuum and cracked at the seam.
Good luck.
Clois
"Let's roll"
"Be part of Something Good
