Old 05-12-2007, 08:57 PM
PCC's Avatar
PCC PCC is offline
Default Lining a Boot
I have some carbon fibre work going into the boot, but I'm looking at re-lining the rest with some good quality carpet.
Doestic carpet seems a bit stiff, so can anyone recommend a wilton type that is pretty pliable?
And where do you get hold of it?
PCC (Peter Craig)
Keep the sun shining
Old 05-12-2007, 09:57 PM
Aussie Mike's Avatar
A lot of the modern automotive carpets have a stiff plastic backing. They are designed to be molded to the shape of the floor with a bit of heat applied to the backing. You can readily shape this stuff using a heat gun and come up with a really professional result. Once you have the shape pull it out and get the edges bound ay a rug shop or motor trimmer.
Mike Murphy
Melbourne Australia
Old 05-14-2007, 05:14 AM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Overlocking
Cameron
