Old 05-20-2007, 05:31 AM
stephen low's Avatar
Default Seals n dash lights
G'day All
Been busy with the sparky Saturday again and were that much closer but he's keeping me busy scouting for parts.
He suggested the use of a warning light to indicate whether the thermo fan had switched on and an over ride switch to make it do so if needed. I'll go with both suggestions and thought that using a green dash light with a diagram of a fan was most apt.
I am chasing a source for this dash light as indicated, does anyone know who could provide this? I've have sent an email to my original source Simon Clemens in WA but am yet to hear back, so thought I'd try the forum. Can anyone help?
I mights as well also ask about sourcing rotary (rotating) switches over the normal toggle type. I need one 2 position (on/off) and one 3 position (off/low/high) rotary switch for the thermo overide and heater/demister fans respectively. Can anyone suggest a source for these switches as well?
Finally am looking at the door/bonnet and boot seals that I need for the car. I know at least two sources from where I can buy the seals but can anyone indicate what the profile is that I should be buying?
Is it a case that the seals vary between kits because of the size of the lip each manufacturer uses on the various bodies? Presumably however the general profiles are similar.
Hoping someone can "please explain".
slowy
