Old 06-09-2007, 05:05 PM
Originally Posted by Aussie Mike
I'm not going to waste any more of my time with Colin, If he can't be bothered to return any of my numerous phone calls what hope would I have of seeing him actually complete a report on the car.
G'day Mike,
I was going to use Colin too but he has also not returned my calls. I have subsequently found out that a family issue has been affecting his work. However, returning a phone call is not hard to do. Colin had engineered RCM's before when he was at Enklemans but now he is on his own he doesn't have the paperwork on the RCM chassis available. So for both reasons I'm using someone else.
Old 06-10-2007, 05:35 AM
Kanga's Avatar
beejay, pipes have been fixed however I will be building a new set shortly, haven't had anytime to work on mine as I have been building a GT40 for a client. The weather isn't the best either so hopefully they will be done once the it turns good. How far have you got with yours?
steve
Old 06-12-2007, 05:25 AM
BMK's Avatar
BMK BMK is offline
Kanga
You mentioned Hoppers for the rego office.
Where is work or home - Geelong??
Email me if you can as I have an aquantance who is asking about LS2'
Bernie Knight
Old 06-12-2007, 09:17 PM
Aussie Mike's Avatar
Hi Kanga, give me a call and drop over if you like. It'd be good to catch up.
Rod, I might have to pop in and say hello when I drop my car off. I'll give you a call.
I've been speaking to the enginner and he tels me I need to organise an engine number as I'm using a crate motor. I rang Vic Roads and they tell me I need to bring the car down with the engine in for them to inspect it. I've then got to take it to the police for them to inspect it. I think I'll be doing that on Monday or Tuesday prior to dropping the car in to the engineer.
I had a reasonably productive weekend on the car. It's now back in stealth mode with the under body system on and the LS6 manifold. The suspension is wound up and I've got 4 1/2" clearance under the lowest point.
I'm working on the electricals at the moment. The headlights and indicators aren't finished yet. The list of things on the white board is getting shorter. I've taken next Monday and Tuesday off work to try and get it finished.
Mike Murphy
Melbourne Australia
Old 06-12-2007, 09:38 PM
Gee it didn't take long from first starting the engine to "nearly ready for rego". Good on you Mike, can't wait to see it with number plates.....
Old 06-13-2007, 01:05 AM
Kanga's Avatar
Mike the engine number sounds like it might hold you up a bit, I think that some on the forum have had the engine fairies come to their address overnight and a number appears on it, funny it is the same number that is on the reciept of purchase. Trust me the biggest hold up you have is going to be with the police, its something that wouldn't get done in the same day, let me know if you choose to go this way and have trouble.
steve
Old 06-13-2007, 02:45 AM
Cobra Make, Engine: classic revival 302w
Best of luck Mike the only thing i sugest is make a copy of all the receipts and paperwork to give to the engineer and take a mirror and torch to vicroads with you they get a little flustered
jess
Old 06-13-2007, 05:24 AM
BMK's Avatar
BMK BMK is offline
Aussie Mike..
Not long now. And a visit to Geelong to shake out..
Bernie Knight
Old 06-13-2007, 02:52 PM
Default Good Luck
Aussie,
Good luck with the Rego, a stressfull time, but think of all the joy you will have when its done.
STIFFY
P.S. Dont give Garrett a go, remember what you did to his car at Winton
Old 06-17-2007, 08:26 PM
Blair's Avatar
Cobra Make, Engine: DRB Cobra, Ford 2001 4.6l Quad Cam Stroked to 5.2l (ported heads, reground cams from SHM + a Kenne Bell 2.8 Charger + Intercooler) Autronic SM4 Ecu, Autometer Cobalt Gauges, Trigo 8 & 10 x 15 Halibrand Knock Offs, Goodyear Eagle Tyres
Well Aussie Mike how are you going? Are you all ready? Everything back to legal yet or are you going to do an all nighter?
Never Piss into the Wind!
Old 06-17-2007, 10:14 PM
boxhead's Avatar
Dont answer him Mike, just get back out in that shed.
Cruising in 5th
Old 06-17-2007, 11:12 PM
I hope you're not reading this Mike, but good luck for tomorrow anyway....
  #33 (permalink)
Old 06-17-2007, 11:36 PM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Mike, put the computer down (unless the car is all ready to go).
Good luck for tomorrow.
  #34 (permalink)
Old 06-17-2007, 11:37 PM
Same here Mike.
Hope all goes well for you.
  #35 (permalink)
Old 06-17-2007, 11:54 PM
Cobra Make, Engine: Classic Revival (CR3204) 6ltr s/c, T56 6spd
1 more sleep Mike
All the best
  #36 (permalink)
Old 06-18-2007, 12:45 AM
boxhead's Avatar
May I suggest a poll.
How long since Aussie Mike slept in the house?
I say 2 days
Cruising in 5th
  #37 (permalink)
Old 06-18-2007, 01:06 AM
Alvin's Avatar
Cobra Make, Engine: DRB COBRA, 302W, GT40 manifold, E303 cam, Trickflow alloy heads, supra gearbox, LSD, commodore brakes, Autronic computer. The car was modified by Doug Pearce
Send a message via ICQ to Alvin
good luck mike.
I hope everything goes well tomorrow
Alvin
akyong1@optusnet.com.au
  #38 (permalink)
Old 06-18-2007, 01:19 AM
Philm's Avatar
Default Good Luck
Good Luck Mike.
But you don't need it.
If your first run is anything to go by you have nothing to worry about.
Phil
  #39 (permalink)
Old 06-18-2007, 01:55 AM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Default Go you good thing
All the best Mike
I can't imagine there should be any issue you haven't thought through a dozen times or so each.
Break a leg!!
Hogster
Darwin
  #40 (permalink)
Old 06-18-2007, 04:24 AM
sambo's Avatar
Good luck Mike. Put the thunder back into the 'dome!
