Like Tree2Likes
  • 1 Post By gjkrv8
  • 1 Post By CHANMADD
Old 09-21-2007, 07:42 PM
Default Side Vent Attachment
Hello
What do you use to bond the steel brackets (holding the Stainless Side Vents) to the fiberglass body.
Bruce
Old 09-21-2007, 07:52 PM
BJ's Snake's Avatar
Hi Bruce
I used Sikaflex which is a silicone adheasive available at Bunnings.
Brett
Old 09-21-2007, 09:22 PM
bobcowan's Avatar
I used body putty to bond a piece of 1" angle alum below opening. I rivited another piece of angle alum to the top of the vent itself. Then I glued velcro to the matching surfaces. The velcro holds the vent in place even on the track.
It's nice to be able to remove them when needed. Makes for easier access for everything in that area.
Old 03-20-2013, 08:25 PM
sambo's Avatar
Raising the dead here... Bruce how did you end up fixing your side vents?
Sikaflex was also suggested to me but I want to be able to remove them a little more easily. Great suggestion from bobcowan, thanks!
Old 03-20-2013, 08:42 PM
BJ's Snake's Avatar
I only used Sikaflex to bond the aluminium angle to the body. The vents are held in by 4 small hex bolts on each.
289 FIA Cobras RULE!
Old 03-20-2013, 09:21 PM
gjkrv8's Avatar
Same here. I even put nutserts on the alum brackets to make it easier to screw/unscrew. Works a treat.
Cheers Gregg
Rog246 likes this.
Old 03-20-2013, 09:09 PM
sambo's Avatar
Yeah I reckon that's the way to go BJ. Good little project for the weekend.
Old 03-20-2013, 10:45 PM
Mando's Avatar
I used the same method as BJ. I Sikaflexed aluminum angles to the fiberglass body then a couple of spots of silicone to secure the vents to the angles. Worked a treat!
Regards.
Mando
Old 03-20-2013, 11:11 PM
CHANMADD's Avatar
The fender badges that I have, have fairly long studs welded to the back ( they came like that) requiring holes to be drilled to mount them. Some inner tube rubber cut to fit behind the badge and on the inside between the vents and the body with holes drilled in the top flange of the vents so the badge holds the top and some double sided tape on the bottom......been there for 24 years with no problems ......I have removed them once for a re paint........very easy .....
OZCOBRA likes this.
Old 03-21-2013, 04:56 AM
renovationinnov's Avatar
macloft
sorry to hijack your thead but how has every one cut out there bodies to fit the vent
as im a chippy i was going to use a router to remove most of the fibra glass then file finish to shape any real answers would help please
rob
Old 03-21-2013, 05:01 AM
sambo's Avatar
The vents I have are slightly bigger than the opening in the body so the only finishing is to even up the lip so there's a flat surface for the vanes to butt up against. If that makes sense?
Old 03-21-2013, 05:44 AM
Modena's Avatar
Same as Sambo, on the CR the body is already open out of the mould, the vents are slightly bigger so just needs a clean-up on the edges of the fibreglass.
Ben in AU
Old 03-21-2013, 02:22 PM
sambo's Avatar
Is there a particular type (number) of sikaflex for bonding fibreglass to aluminium and do we need to use the sikaflex primer?
Old 03-21-2013, 03:15 PM
BJ's Snake's Avatar
Sambo
From memory there is a sealant and a adhesive, use the adhesive and all I done was clean surfaces with oil and grease remover. 7 years, haven't moved.
BJ
Old 03-22-2013, 02:01 PM
07cob's Avatar
Paul
Sikaflex 11FC is the goods for adhering.
Geof
