November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-09-2007, 04:11 PM
boxhead's Avatar
Default Time for an update
Hey there all the boys and girls in Cobra land.
I recently had some time of work and put some more work into the Cobra.
Following are some pictures.
Engine pulley setup.
R/H side under car headers (for rego) all made.
L/H side under car headers (again for rego) all made.
Underside all painted.
Fuel lines and vapour lines around tank all routed and secured.
Cruising in 5th
Old 10-09-2007, 04:56 PM
stefanog's Avatar
Cobra Make, Engine: Robnell BB 429 (Sold) Contemporary Cobra CCX3682
Default Nice work!
Boxhead, coming together very, very nicely!
I like!
Stef
Life really is beautiful!
Old 10-09-2007, 05:51 PM
stephen low's Avatar
Looking good Boxhead, though a shame about the darkside factor there!!
How did you flip the body for painting, lots of (un)willing helpers?
slowy
Old 10-09-2007, 06:10 PM
sambo's Avatar
Good to see another 'open air' garage! Coming along nicely Boxhead.
What kind of seats are you using? I like the gauges too, what are they?
Old 10-09-2007, 07:25 PM
boxhead's Avatar
The seats I bought off eBay acouple of years ago, from memory they where about $250 for the pair.
The gauges are all pricol except the clock (they dont make one) so it is smiths.
It is only the body that is in the open air, the wind blew up on Sunday night and it has moved about 18 inches. I have put it back on the tyres again and tied it down now.
It will most likely be that way for another week (waiting for some rubber lined "P" clips to secure the fuel lines inside the trans tunnel.
Then it is time to call my mates again to flip the body over and paint the engine bay, I will go with a black engine bay for now (plan to line it with aluminium later).
After that it is hopefully body back on for the last time.
Get the AN braided furl lines made and start the bastard for the first time.
I will button up and bled out the clutch and brake system before I start it, cause it would kill me to hear it start and not be able to move it under its own steam.
Cruising in 5th
Old 10-09-2007, 08:05 PM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Hi Box Head
Can you put a pic of the fuel tank straps up? I got a VS tank and are having trouble fitting it. Theres no room to change the fuel pump!
Old 10-09-2007, 08:32 PM
Aussie Mike's Avatar
There should be something in the build manual about that.
Mike Murphy
Melbourne Australia
Old 10-09-2007, 09:07 PM
PCC's Avatar
PCC PCC is offline
David,
Looking good!
See you have a rubber tree in the background.
What sort of tyres does it drop?
PCC (Peter Craig)
Keep the sun shining
Old 10-09-2007, 11:47 PM
boxhead's Avatar
Originally Posted by alffie
Hi Box Head
I bought my tank and the straps from PhilN, the straps where allready cut to suit the CR chassis, The front mounting holes where allready in my chassis with nutserts installed, I welded some all thread on the rear crossmember (behind the tank) and tighten up with nuts to secure the tank.
There is no access to the intank fuel pump with the tank in situ.
Cruising in 5th
Old 10-09-2007, 11:50 PM
boxhead's Avatar
Originally Posted by PCC
David,
Looking good!
The tree in the background drops Desert Duellers, but they allways have no tread on them.
Cruising in 5th
