Old 10-13-2007, 01:28 AM
Default LS1 Engine fault light connection
Hello LS1 brains trust.
I am finishing off the dash wiring and want to know what wire/output to connect the Engine fault light to and the Not charging light to.
Bruce
Old 10-13-2007, 02:51 AM
aussie ls1s do not have a warning light
it all goes thru to the dash
find a usa ls1 wiring diag as they have a mil light
but then u have to retune the ls1 ecu to get the light to work
i have gone thru stuff with people i deal with and think i have figured it out
but ask your tuner first as he has to turn it on in your ecu otherwise it wont work
its not a simple just plug in a wire and go for it
i could set yr ecu up but it would cost you 300 bucks
ls1 fly by wire alternator wires go straight to ecu
u have to not connect these to ecu and find out what the wires do then connect them to i think battery and charge light in dash
my website
www.sideshowsperformancewiring.com.au
Old 10-13-2007, 06:15 AM
Got them. I have found the charge indicator signal wire and as mine is a US engine/pcm I also have a working MIL connector out of the PCM (I didnt know what MIL stood for)
Thanks Sideshow
Bruce
Old 10-13-2007, 06:57 AM
Philm's Avatar
Default The truth
An easier solution is to hard wire the engine warning light so it is on permanently
Phil
Old 10-13-2007, 04:03 PM
im about to buy a new diagnostic scanner
you could always buy one of these for 7 g
and mount it in the dash
first thing is if you are goin to run a mil light then make sure yr tuner sets it up ok
u have to go into the tuning software and make sure u turn afew things off
so the light doesnt come on for wrong reasons like aircon or stuff thats not goin to be fitted
another thing i would not mind doin one day but no cobra owner has gone this way
y not run the ls1 dash
i recently wire up an ls1 in a holden eh show car and customer wanted matching dash
then afew weeks later i bought for the owner a red monaro dash his friend mounted it and i wired it up
it looks sooooo hot
the eh is hot red and the dash has full red dials
i think someone who wants a modern futuristic looking cobra should do this
if i had one this is the way i would go
but for now my future dream car is a 61 corvette with a new holden efi engine and fully electronic matching dash
my website
Old 10-13-2007, 10:23 PM
Like this:
The white HSV dials match the white seats which was a complete fluke!!!
I have run the entire Commodore body loom with BCM, PIM and PCM. My car is basically a Commodore (in a lightweight body) with all functions such as cruise control, trip computer, auto headlights etc. etc. All standard fuse blocks and relays too... if down the track I ever sell this car, the owner can just take it into Holden for servicing.
This made setting up things such as lights, indicators, brake lights an absolute breeze.....
I just need to get my alloy trim for the gauge cluster cut on the water-jet machine (thanks to Cobber for the CAD work), then clearcoat the Carbon fibre so it looks cool!!!
Old 10-13-2007, 11:14 PM
OZCOBRA's Avatar
Originally Posted by Plums
Like this:
Plums...
Are you going to run with the full CARBON dash on the passenger side or is a glove compartment coming ...IMO don't you think a compartment or even a fake door would break up all carbon and match the shape of the cluster ..just to give a balanced look???
Great use of the technology though.
Paul
Old 10-14-2007, 12:31 AM
Philm's Avatar
Default A new bench mark
Plums,
Love what you have done, to use the complete commodore system is absolute genius.
Dash looks hot.
Phil
