questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
10-26-2007, 04:08 AM
NSW
I decided to lower the whole drive train,the floor and the seating arrangement. This resulted in a zero degree(horizontally) alignment of the tail shaft. Seats that leave you below the windscreen, seatbelts that stay on your shoulder and no room for trailing arms. I bought a set of Watts Links from Ken Karcevski from Cobra Craft,Peakhurst, Sydney and this set-up is fully adjustable. It is retrofittable but I changed this whilst the car is in bits.
The alignment has yet to be tested at speed, but being spanner adjustable I'm probably in for a bit of fiddling.
10-26-2007, 05:21 AM
WA
Update
I painted up my new arms (thanks Harrmac) and had them ready to install. I pulled off one side (I thought I'd better check them before I go putting it all back together) and they are identical to the arms I already have.
This means that I basically have the maximum amount of Castor available, and that's with the offset arms. If I had to use symmetrical arms I would only have about 1 - 1.5 degrees
I think after rego I'll need to do some front end "re-engineering"....
10-26-2007, 06:11 AM
QLD
Bobby, are your lower arms series 11.
The series 1 lower ball joint is 1/4" further back than a series 11.
Or......
If series 11 lowers, do you have them on the correct side of the car.
The lower ball joint stub on a series 11 should curl forward....not back.
10-26-2007, 06:42 AM
WA
The lower arms seem to be correct, i.e. if you swapped sides I think you'd end up with no castor.
Rob from G-force reckons that 3 degrees of castor is enough, but I want more!!!
10-26-2007, 06:45 AM
QLD
I know where your coming from Bobby.
I moved my top arms back 10mm and took all the anti dive out of them. (ie. they are now parallel with the lower arms.
cheers
10-26-2007, 02:32 PM
AUS
That's also what I would like to do after getting advice from Rebel1 & OzVenom.
10-26-2007, 03:19 PM
QLD
Craig, I'm sure Scotty will get that RMC of yours cruising like a limo with perfect manners.
A lot of the info I have came from Jaime Garde who was the employed engineer at RMC.
His job involved improving the RMC chassis by experimentation with their race car.
I believe the then owner of RMC, Mike Moylan, was involved in motor sport and competed in Targa Tasmania a couple times with the cobra.
However, the handling improvements never made it to the production Jigs mainly because the business was put up for sale.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
