November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-30-2007, 06:22 AM
LoBelly's Avatar
Default Outie
On Saturday I made a start on the heart/lung transplant.
Its all fairly standard stuff so have just added some descriptions below the pictures.
There seemed to be a paucity of car stands so the gantry did duty lifting the Cobra to working height until Matt came with the stands and the new toy.
The new toy is the engine crane - one of the several pieces of equipment that I have a 1/2 share in that will never come to my place. In this shot we're discussing how to explain to enquiring spouses why an engine crane is necessary when there is a big-a$$ gantry exactly above the engine bay of the car - (silly women)
The engine is free of the car - seems to have dragged the transmission out with it. Having convinced me that there is no way I could consider just freshening up the engine and running it for couple of years my brother has now discovered a use for it (!) By the look of him Matt is also considering some options.
Now somewhat lighter in the front end the car is pushed outside for a degrease before being put away for next weeks activities.
Any guesses where the coolant may be leaking?
Don't 'spose we'll be able to tell 'till we get her apart...
until next time.....
LoBelly
Old 10-30-2007, 03:31 PM
David Hodgson's Avatar
LoBelly,
Whats the plan then if you are not using the 289?
It's gonna be anothe blue oval isn't it..........ISN'T IT!!!!!!
SLIPRY
Old 10-30-2007, 04:57 PM
BMK's Avatar
BMK BMK is offline
LoBelly
The engine lift stays now that it is your possession. Good luck with the build.
Bernie Knight
Old 10-30-2007, 05:10 PM
boxhead's Avatar
Looks like there is enough room there for a LS series motor, imagine how much beter your car will handle with so much less weight over the front?
Cruising in 5th
Old 10-30-2007, 05:32 PM
I was thinking exactly the same thing.
Imagine how much harder it would go with an LS series.
Old 10-30-2007, 06:10 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Don't listen to those "Dark Side" whispers! A nice little Windsor with Cleveland heads would do the trick. Must say I like those Japanese safety boots that you all wear in the workshop.
cheers
Doug
Old 10-30-2007, 06:53 PM
400TT's Avatar
One word...Stroker.
I've built 2 x Cobras with my brother in the past and both of us built the cars in our bare feet.
www.absolutepace.com
Old 10-30-2007, 06:58 PM
LoBelly's Avatar
Smile Soft Option
I have to confess that I'm one of those oddballs who put 'Jedi' down under Religion in the last couple of census. (plural form?)
Consequently I am duty bound to stay away from the dark side.
However, cognisant of the weight differential, I'm going with one of the shorter deck height blocks and Don has helped me out by removing excess material from within the block (mostly from within, or the bottom of, the cylinders) Applied alchemy will result in the conversion of iron to aluminium for some components to further help in this regard.
Hopefully this will result in more of a swap than a conversion.
I guess you LS lads can show me the way around the track at the next ShelbyFest
LoBelly
Old 10-30-2007, 08:41 PM
boxhead's Avatar
Ok then, if you want to keep it boat anchor blue, I do understand.
How about fitting 4 of those Italian down draught carbies?
Cruising in 5th
Old 10-30-2007, 08:44 PM
Cobra Make, Engine: RCM, 4 wheels, two doors
Stay true to the Blue side Lobelly. Pay no attention to those darksiders!
Those darksiders are always comparing apples with oranges. Turn your 289 into a 347 with a nice cam and heads and you'll eat those LS thingies for brekky!!!
Old 10-31-2007, 01:40 AM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
I've got a 289 long motor, 030 over, mild crane cam, forged pistons, high volume oil pump, Ported 302 heads, blah blah. Its just sitting there now that I have gone with the 5.0 litre/347 stroker.
If you are interested PM me.
Hogster
Old 10-31-2007, 09:57 PM
LoBelly's Avatar
Default Replacement engine ready
Thankyou for the offer Hogster, however I have just received a ransom note and instructions collect the replacement this Saturday morning.
Hopefully I'll have some more shots of the Innie some time next week (if I can come up with the $$).
LoBelly
Old 10-31-2007, 10:05 PM
Wazza's Avatar
[quote=LoBelly]I have to confess that I'm one of those oddballs who put 'Jedi' down under Religion in the last couple of census. (plural form?)
These sort of things bug me....had to find out as well...
Answer:
Even though the word census is of Latin origin, and in ancient times the plural would probably have been censi, in common usage today the plural is censuses.
Back to work....must stop reading Forum.....must not spend "work" time looking up the plural form of census, when , If you had've written CENSUZZEZ most of our guys would've copped it sweet !!
Regards,
Warren
Old 11-02-2007, 06:35 AM
Lobelly,
Your shed is disgusting. It is clean, tidy and has midget workers there as well.
As far as japanese work boots go. I ventured into my shed yesterday without boots and within ten minutes damaged my already broken little toe again.
