Old 11-29-2007, 12:06 AM
Default 5 speed options
I have been going around in circles for weeks trying to decide which way to go, have narrowed it down to the uprated version of the t5 or tko 5oo, currently have a single rail 4 speed behind a 302w. Any advice would be greatly appreciated.
Stuart
Old 11-29-2007, 12:31 AM
Tony Cram's Avatar
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Default Diff Ratio
Stuart,
What diff ratio are you running?. You will need to choose your fifth gear and possibly your first gear ratio to suit your diff. TKO 600 is a good option.
TC
Old 11-29-2007, 01:08 AM
Stuartt, Read the following about gearing:
http://www.clubcobra.com/forums/show...309#post730309
It was written prior to the release of the TKO 500/TKO 600 but first you have to get your head around the gearing. ie. the relationship between 1st and 5th gear,
your tyre size, and your diff ratio.
Also as the above site mentions, you will have to make a decision to gear for the track or the street.
Hope that helps.
Old 11-29-2007, 01:36 AM
Tony Cram's Avatar
Default Some reading for you
Stuart,
I have attached a gearbox ratio calulator. It takes into account Diff, Tyre, Rim and gives you revs at different speeds on various Gearboxes.
Also check these websites for more Tremec info
http://www.moderndriveline.com/Techn...its/tremec.htm
http://www.malwoodauto.com.au/
and CAPA Performance in SA had Tremecs at a great price a few months ago.
http://www.capa.com.au/eaton.htm
TC
Old 11-29-2007, 01:59 AM
capa want $4000 for a tko, cheapest price i have come across is $3300 from doug pearce
Old 11-29-2007, 02:50 AM
Philm's Avatar
Default Tko 600
HI Stuart,
If the 302 is pretty stock I would stick to a T5, they shift well and if you get the Mustang or world class they can handle a 302 windsor.
I run a TKO 600 with 3.9 diff and 26inch wheels. The 5th ratio I have is .6 which is great for freeway use and the close ratio 1 to 4th is great for the track.
I bought mine from Summit racing and with the dollar as it is you would probably have it delivered to your door for about $3000.00.
Phil
Old 11-29-2007, 04:38 AM
wtm442's Avatar
Beam Me Up Scottie
Here is a nice gearing calculator.
http://www.secondstrike.com/Technical/GearCalc.asp
Warren
Old 11-29-2007, 12:57 PM
schipps's Avatar
Originally Posted by Philm
HI Stuart,
Phil
Phil,
How do you fit those wheels in the guards???
Mick
Schipps
Old 11-29-2007, 04:14 PM
Default An auto for you my friend....
Stuartt,
I remember the first time you drove a Cobra with a 5 speed TREMEK...... I thought Skippy the bush kangaroo had made a come back..
For those of you that were not there, I let Stuartt drive my car on this years Alpine Run, it was very funny watching him give himself "whiplash" THEN "tyre smoke" "whiplash" THEN "Tyre smoke" he needed to go to the Chiropractor after thye event..
abd the car needed new Engine and Gearbox mounts.........
STIFFY
Old 11-29-2007, 02:47 AM
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Consider buying it from the US and save yourself over $500-00.
I paid $1850 USD from Summit racing for a Ford Performance Box that is identical to TKO 600, just sold as a ford box Good 1st gear and overdrive ratios which can be an issue. It arrived at my house in Darwin 8 days later, including road freight across the US. Freight was about $300 USD.
Very happy with the result
Hogster
Old 12-01-2007, 05:34 AM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Hi Stuartt
I have a 5spd tremec with the shifter in the centre position for sale if you are still looking
Craig
Craig W
Central Coast NSW
Old 12-01-2007, 07:12 AM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
I just bought a GForce T5 with the various strengthening upgrades, and the .75 overdrive. I think the previous commenter was right, if you are under 400hp stick with "world class" or greater T5. Reason: it can handle the load and it's lighter than the TKO. And they are el-cheapo. If you are > 400, then you could do what I did, or go with the TKO. The upgraded GForce T5 is heavier than the stock unit, by how much I don't know.
If I can see you, I'm too close
Old 12-03-2007, 05:27 AM
cobra.au, give me a call i have sent you a pm with my phone no.
