Old 02-02-2008, 04:00 PM
Cobra Make, Engine: Superformance (AUS 09 or SPF 2792) - LS7 427ci
Default How many LS7s are out there?
Hi all,
I'm curious, how many LS7's are out there either up and running or in the construction phase?
I've taken the plunge and would like to hear from any others who have gone the LS7 route...
Regards.....Paul
Old 02-02-2008, 04:15 PM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
I ve got one. dont know of any other Cobras out there, has yours arrived yet? Howd ya go with your T56?
Old 02-02-2008, 04:54 PM
Philm's Avatar
Default Should be banned
I think there are just too many LS7s out there and there use in Cobras should be banned
Seriously, the ultimate cobra combo, LS7, Tko 600, 9inch and a big set of balls.
Phil
Old 02-02-2008, 05:37 PM
Phil
I'll second that ...actually a healthy LS2 with good heads, nice cam and valve springs would be the goods. $hitload cheaper
Hang on ..... That's wot I've got in the L76.
Old 02-02-2008, 05:40 PM
coco_cobra's Avatar
Cobra Make, Engine: DRB 1996 302 windsor
phil i agree and all of them use top loader and 9inch why 2 make them stronger they have nothing like a 9inch nad top loader
Old 02-02-2008, 09:39 PM
acecob's Avatar
ask me )
Old 02-03-2008, 06:55 PM
pneall's Avatar
Rebel,
I'll let you know how good that L76 combo is in two weeks
Slow 427 reckons its awesome
Phil
Old 02-04-2008, 12:53 PM
Heidlberg
Are you using the GM oil tank and ECU? Did you get the maffless tune aswell?
Old 02-04-2008, 02:39 PM
Cobra Make, Engine: Classic Revival 3506
If you can keep a LS7 on the road or in a straight line, i take my hat off to you. Too much power and a short wheel base doesnt equate to a good car. Ask any race driver .
But it does make tyre companies VERY happy.
And as for Ford 9 inch diff's as good as they are the housings do break very easily.
Old 02-04-2008, 05:36 PM
Originally Posted by pneall View Post
Rebel,
Phil
Phil, I'm really looking forward to some-one posting their impressions.
Have you changed cams to take advantage of those nice heads?.
I've been told they can get a bit breathless above 5000RPM because of the tiny cam but that came from a ford mechanic so dunno if it's true.
Old 02-04-2008, 06:49 PM
pneall's Avatar
Les,
Yes have fitted cam and hoping for around 420 RWHP and an engine with very different torque characteristics compared to the LS1.
Phil
Old 02-04-2008, 07:01 PM
Les,
Phil
NICE ...
Phil, I can hardly wait for your impressions.
Les
Old 02-04-2008, 07:07 PM
sambo's Avatar
I second that one Les... not sure I've heard any feedback on this forum from an L76/98 Cobra owner.
Old 02-04-2008, 07:31 PM
Sambo, I have no doubts the L76 will prove to be more than a stout performer.
I also have a cam change planned after rego but I'm real eager to hear about the torque characteristics.
I'm a little different to most of the L76 owners cuz my diff is a 3.31 behind a TR600, 5 speed.
I think most here are running the T56 and diffs lower ( higher numerically) than 3.5X.
Old 02-04-2008, 09:08 PM
I have a L76 in a classic revival with a cam and a few other bits and may i tell you they pull like a freight train FOREVER !!
671 N.M @168KPH
313.6 rwkw @196KPH
Old 02-04-2008, 09:18 PM
671 N.M @168KPH
313.6 rwkw @196KPH
Thanks for that ptrefry, appreciate the comments.
What rear gears you running?
Old 02-05-2008, 07:19 AM
I am finishing a Cobra with aluminum backbone chassis, carbon fiber body, LS6 engine, T56 trans, Corvette Diff 3:42 gear converted to accept a driveshaft, and Corvette independent suspension. I am planning to put an LS7 in a second one but with a Daytona coupe body. The body is a fiberglass carbon fiber hybrid. It has a layer of glass to prevent print through and then a layer of carbon fiber for strength, stiffness, and to keep everything light. The finished car weighs 1900lbs. I'll let you know how it goes. I will be selling this car as a kit. Obviously a Ford engine can be used too.
Old 02-07-2008, 03:19 PM
Im using standard AU IRS falcon diff.
