Old 02-18-2008, 01:17 AM
Cobra Make, Engine: RCM
Default Ls1 Wiring Loom Question
NEED HELP Can somebody tell me if the wiring loom on the motor needs to be modified to start engine I know the vats need to be done any help would be great thanking you in advance HISSIN
Old 02-18-2008, 01:44 AM
Hi Hissin
You need to supply power to the PCM and to the coils and injectors. To do this you need to break into the particular wires in the harness.
You need a wiring diagram for your particular motor harness, there a number of guys on the forum (including myself) who can forward these just let us know what motor you are running.
Do you have a harness that has all the relays and fuses for the for the starter, fuel pump, coil and ignition functions already or do you need one made.
Here also guys can lend a hand, either getting one through sideshow (who will soon pop up) or buying a ready made one from the many suppliers around.
It is a great feeling to see/hear the motor start after you have done all the wiring yourself.
Bruce
Old 02-18-2008, 06:10 PM
Tenrocca's Avatar
A mountain of info here:
http://http://www.ls1tech.com/forums...d.php?t=312119
Old 02-19-2008, 02:12 AM
Hi Hissin
Send me an email to bagw@bigpond.net.au and I will sen you the wiring diagrams
Bruce
Old 02-19-2008, 03:32 AM
cobbindale's Avatar
Cobra Make, Engine: Classic Revival.
G'day Hissin
If your chasing a Holden engine management manual, I have one in PDF format. Helps if a Holden loom.
Also have pin out and T56 Manual as well.
Dale.
Old 02-27-2008, 11:19 PM
u need to fit relays for pumps fans maf and o2s
and some fuses for all the relays
u need a diagnostic plug aswell
what parts do u have
i have 2nd and ls1 looms and ecus etc
can supply u stuff from ecu all way to modified loom
i have 4 l76 looms to start on next week
i have a sort of production line goin next week
heheheh
my website
www.sideshowsperformancewiring.com.au
Old 03-01-2008, 03:49 AM
Hi Brains trust can someone else send Victor (Hissin) the wiring diagrams for his LS1. I have tried for days and can not seem to get them through. Craig White and others could you try please and help him out.
Thanks
Bruce
Old 03-01-2008, 04:38 AM
just do a search on google for diagrams
u dont need no brains trust to find diagrams
any joe blow can figure this out
my website
Rate This Thread:
