Old 03-09-2008, 01:48 AM
Tenrocca's Avatar
Default Second time around...
It goes together a lot quicker. I decided to the front end off to respray that part of the chassis before the body goes back on for the last time in a couple of weeks. Quite a few little mods and touchups of the paint were looing a bit ordinary.
Back to bare:
You can see the bottom tabs for the steering rack- a must do mod on the CR:
going back together:
In goes the donk and box:
Wiring back in place:
Tailshalf safety hoop and tail shaft:
T56 Clutch line and remote bleed:
All on one Sunday - best of all I can now put it in gear to stop it rolling away! Exciting
Old 03-09-2008, 03:46 AM
Gav's Avatar
Gav Gav is offline
Your eye for detail is great. Mine gets pulled apart only for repairs, and that happens all to often.
Powered by Cu
Old 03-09-2008, 04:26 AM
albanycobra's Avatar
Nice work Mate
Keep the updates coming.
Old 03-09-2008, 04:39 AM
Tenrocca's Avatar
Its hard enough just keeping up with the updates in your "Cobra make" sig Dave. "FFR65 coupe" - you would be breaking new ground there. Not sure if there are any FF's in Oz, let alone a coupe. Further details needed
Old 03-09-2008, 06:06 AM
PM sent Bud.
Old 03-10-2008, 06:29 PM
Damn, that huge hunk of alloy looks good sitting in there.
Wished I had one of them.
Old 03-11-2008, 02:01 AM
Tenrocca's Avatar
I know Les - every morning I wake up, thank the gods of the dark side that I wasnt tainted with that strange infliction that makes one want to defy all logic and actually put a ford in one of these things...
Old 03-11-2008, 03:08 AM
BJ's Snake's Avatar
F&%# I think i'm going to be sick!
289 FIA Cobras RULE!
Old 03-11-2008, 03:11 AM
acecob's Avatar
Me Too :jekylhyde
Puke
Old 03-11-2008, 03:24 AM
Tenrocca's Avatar
Like shooting fish in a bucket Les.
Old 03-11-2008, 04:05 AM
Yep...sure is mate...
Too easy
Old 03-11-2008, 02:03 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Didn't realise you were building a boat! That anchor you have in the front looks like it will hold harder than a danforth.
Old 03-11-2008, 04:36 PM
boxhead's Avatar
I cant see anything that weighs enough to be used as a boat anchor in any of the pictures
Cruising in 5th
Old 03-13-2008, 02:33 AM
Its interesting from the pics to actually see how close your feet are to the extractors.
Hows the hot feet in these babies fellas?
Old 03-13-2008, 02:52 AM
Tenrocca's Avatar
i dont think its a huge issue. Not many have complained that Im aware of of overly hot feet. I have a layer of cork sandwhiched between the glass and aluminium panels in the engine bay for insulation - so Im pretty confident that should keep it comfortable enough. I may end up ducting cold air fron the front brake ducts and feed into the footboxes down the track if need be.
The cast manifolds will be going pretty soon BTW - so it might be deceptive just how close they are - that said there isnt a lot of room between the footboxes and wheel wells for the pipes to exit.
5 days till the body goes back on for the last time..
Old 03-13-2008, 05:00 AM
Philm's Avatar
Default Busting to do it
Andrew,
You must had had that quote on your desktop and you were just busting to use it.
I enjoy the fact that my car has what looks like a small block Windsor, but to do it agin it would have an LS7 and a tko600 behind it.
See you on Wednesday, looking forward to it.
Phil
Old 03-13-2008, 05:56 AM
Originally Posted by Philm View Post
Andrew,
Phil
Now there's a traction problem just waiting to happen .
Old 03-13-2008, 03:00 PM
Aussie Mike's Avatar
It's great just working on the bare chassis. I'm looking forward to giving the paint on mine a spruce up when I pull the body for paint.
I haven't found the foot box heat a problem. I'm running side pipes though and I reckon it'd be a different story with an under body system. The HPC coating on the pipes realy cuts down the radiated heat.
Mike Murphy
Melbourne Australia
Old 03-13-2008, 11:37 PM
Good to hear. From the pics it looks like only cm's between your tootsies and the pipes. But if heat is not an issue..cool. (no pun intended)
