04-08-2008, 09:37 PM
NT
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Dash layout
Hi all
Ive got my gauges now and are trying to work out the best layout for them. Any ideas/pics would be great.
04-08-2008, 10:33 PM
NSW
Originally Posted by alffie
Hi all
Alfie,
This is how I set mine out.
Baz.
04-08-2008, 10:42 PM
Cobra Make, Engine: Scratch built Bowtie, C4 suspension, Fiberjet body, 427 Rat
Did mine this way.
04-08-2008, 11:23 PM
NSW
Alffie - not sure if your using Ians dash - with the smallish gap between the column shroud and the cowl, I found it hard to make room for any smaller gauges as per the period correct SC layout - so had to compromise and put both smaller ones to the right of the wheel.
04-08-2008, 11:28 PM
VIC
Here's mine.
Get some pictures of the guages you intend to use or different ones you are considering. Scale them up to the right size using photoshop or whatever and print them out and glue them to some card board. Cut them out and stick them on with blue-tac in different layouts till you find one you are happy with. That way you can try the layout from the drivers seat and see how it looks before cutting holes in your dash.
Mike Murphy
Melbourne Australia
04-08-2008, 11:34 PM
Vic
I think there is a dash picture in my gallery, not sure how to do the link to it here. But space is an issue running modern column shrouds and steering wheels.
Didn't want to lose the vision of my good gauges to the right hand side of the column, in that dark space next to the door so, like tenrocca the two large gauges next to each other and the five small in the middle.
Depends on the look you like and what you want to achieve. Functionality was one of my wants, so a gauge tucked away in a hard to see spot just wasn't what I wanted.
I printed out a number of layouts and studied them till I had a prefered option. Another trick I did was to photograph the gauge faces, print out to size match the actual gauge diameters and then just layed them out in my preferred patterns.
If you can do this on an insitu blank dash, you will be as close to actual as you can get. A bit of work I know but then you wont be disappointed later.
ps who can tell me how to post a link to pics in my gallery?
pps beaten by Mike by a nat's something, but eliminate his lowest small gauge and that is my layout too. Maybe I liked Mike's set up I can't recall now.
slowy
04-08-2008, 11:48 PM
VIC
04-09-2008, 12:28 AM
AUS
Here is my dash, it's the SC layout.
Mike's suggestion is a beauty. Cut and paste images of your gauges to fine tune your dash layout, great idea.
04-09-2008, 12:50 AM
VIC
Very nice traditional looking interior there Craig. Is that your RMC?
Mike Murphy
Melbourne Australia
04-09-2008, 01:21 AM
NSW
Here ya go Alffie
Nice and simple!
Brett
289 FIA Cobras RULE!
04-09-2008, 02:44 AM
AUS
Thanks Mike, Yep, that's my RMC.
It's very old school or original or classic...whatever you want to call it.
Will post some full photos once I get everything finished off.
Best of all, it has that classic feel when you drive it. Not surprising with 16" steering wheel and top loader.
I'm stoked with the results.
04-09-2008, 03:29 AM
WA
Cobra Make, Engine: Homebush body
hi
here is how mine is layed out
Trev
04-09-2008, 03:53 PM
vic
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Slowy's dash
04-09-2008, 04:00 PM
vic
My layout. Am still waiting for thr polished timber section which will suround the guages/radio/switches & clock
04-09-2008, 04:05 PM
NT
Here is mine, The gauges are not centred in any way, I wanted to be able to see all clearly from the drivers seat.
The speedo and tacho are both visable past the steering wheel with no interferance in your view.
Cruising in 5th
04-09-2008, 04:31 PM
04-09-2008, 04:47 PM
04-09-2008, 06:28 PM
Vic
Thanks Doug, you'll have to teach me how to do the link.
Alfie
Wazza's contribution will get your head spinning but at least you can see options.
A critical factor to take into account is the size of your gauges. The dash space isn't huge in these cars so getting a full set of large diameter gauges can be tight. Some of Wazza's images seem to show all gauges easily placed but I am betting the larger tacho/speedo gauges are only 80mm diameter rather than say 100mm. Most small gauges are 50mm anyway
I also went for the fully infilled dash to give me more space and the very large vacant space shown in Letsboogie's pic of my dash is to accomodate a stereo down the track.
However all my gauges are visible as well, again a functionality issue I wanted to achieve.
More food for thought.
slowy
04-09-2008, 08:24 PM
VIC
My Autometer guages are huge. The tacho and Speedo are 125mm and the smaller guages are about 68mm in diameter. That's why I'd reccomend printing out fullsize pics of the guages and sticking them on in different layouts. What looks OK in a drawing may not work when you actually start drilling holes.
Mike Murphy
Melbourne Australia
04-10-2008, 09:41 PM
NSW
I've just picked up my dash from the trimmers and I'm quite happy with the job that he has done. I still have to fit the warning lights, switches, glove box lock and ignition.
Baz
