11-28-2008, 03:42 PM
Vic
Recommended trolley jack
My el cheapo trolley jack I've had for a long time finally died, and with the rebuild and general use need in the garage I have to replace it.
Want to get a well built decent jack this time, what can peple recommend?
Would like to get a low access model for the cobra but with 2T+ lift capacity for the family cars if needed and am happy to look at alloy versions too.
What can you guys suggest?
slowy
11-28-2008, 05:24 PM
Cobra Make, Engine: Kirkham, 427 side oiler
Is that south of the border for "floor jack"??
11-28-2008, 10:17 PM
VIC
Most of the aluminum trolley jacks are only rated to 1Ton. I bought one recently and its great for the cobra. One Ton will probably be plenty for a family car. You are only lifting one end at a time.
Mike Murphy
Melbourne Australia
11-29-2008, 03:55 AM
Vic
So whose jack did you buy Mike?
Googled trolley jack and found a few good options including something from Hare and Forbes alloy 1T 90 - 450mm lift $330 or a steel low access version capable of 2T and 510mm lift.
Car4jim, trolley, floor, bottle, slide, scissor - doesn't too much matter what you call the jack, so long as it lifts the car - eh??
slowy
11-29-2008, 04:05 AM
VIC
I bought the Hare and Forbes jack. The thing I liked about it was it has a 2 stage pump for the quick lift action. Many of the aloy quick lifts use a single larger pump and a longer handle for the extra leverage.
Mike Murphy
Melbourne Australia
11-29-2008, 04:12 AM
Vic
What was the model number Mike?
slowy
12-01-2008, 06:23 PM
VIC
Slowy, I bought an aluminium jack off eBay for around $300. It's low profile, double piston, etc. eBay only shows max 60 days of shopping history now so I don't have the link, but a quick search revealed literally dozens. Mine's made in China but shipped out of Sydney or Newcastle I think.
It's similar to this but has individual castors at the front and seems a bit longer.
Paul
12-01-2008, 07:47 PM
VIC
Mike Murphy
Melbourne Australia
12-01-2008, 08:40 PM
Vic
Thanks Mike but I actually found the place in my travels so dropped in and looked at that trolley and a steel variant.
the ali trolley manages 90 - 500mm odd travel for 1T and the steel is 110 - 450mm for 2T and about $100 less cost.
Given it is just for the workshop, and I'm used to a steel jobby, I think I'll end up with the steel one and no worries about lift capacity.
Thanks for the details anyway.
slowy
12-02-2008, 05:13 AM
VIC
I've got a 2.5 ton all steel trolley jack as well but it's bloody heavy. I got tired of lifting it in and out of the back of the Land Rover. The last thing I need is to do my back in again.
Mike Murphy
Melbourne Australia
12-02-2008, 05:32 AM
Here's the next one I'll purchase. Price is right, and the 2 3/4" minimum height is much needed for my car.
http://store.summitracing.com/partde...5&autoview=sku
12-02-2008, 12:44 PM
Qld
Bad Backs
Mike,
I bought the same jack. Like you the steel uniits are just too bloody heavy.
Phil
12-02-2008, 01:29 PM
Vic
I'd have been far happier if I could source an ali jack of about 1.5 T capacity.
Anyone sighted one rated to that sort of load about?
Do like the summit version but hate to think what the conversion rate would be at present.
slowy
