Old 12-03-2008, 12:13 AM
Baz's Avatar
Baz Baz is offline
Default Build Update
75 litre baffled aluminium fuel tank installed:
Twin 3" diameter Roll Bars installed.
Lights and blinkers installed.
Wiring Harness installed.
6 litre 307 kw V8 and 6L80E Tiptronic Trans going in next week after Comp Cam and Crane Dual Springs installed.
Pics on my Gallery.
Baz
Old 12-03-2008, 12:44 AM
boxhead's Avatar
No pictures of the engine bay yet Barry
Cruising in 5th
Old 12-03-2008, 01:19 AM
Baz's Avatar
Baz Baz is offline
Hopefully there will be a series next week Boxey on the full installation. Fingers crossed.
Baz
Old 12-03-2008, 02:57 AM
Default Engine mods
Baz,
I take it from the pic's that the car is to go through rego and engineering????
Why the cam before this?????
STIFFY
Old 12-03-2008, 04:47 PM
Baz's Avatar
Baz Baz is offline
Originally Posted by stiffy View Post
Baz,
STIFFY
Stiff,
A lot less trouble putting the cam in when the motor is on the rack that when it is in the car. I have been assured that I won't have any problems with emissions when the time comes.
Old 12-03-2008, 05:05 PM
boxhead's Avatar
Baz
Hey Baz, I assume you are talking to me?
If so my name is Boxhead - or David.
Cruising in 5th
Old 12-05-2008, 12:08 AM
Baz's Avatar
Baz Baz is offline
Sorry David. Your call.
Baz
Old 12-06-2008, 02:10 AM
Baz's Avatar
Baz Baz is offline
Old 12-07-2008, 02:01 AM
Mando's Avatar
Thanks for the pics and keeping us up to date, looks like your making good progress.
Regards.
Mando
Old 12-08-2008, 10:15 PM
Baz's Avatar
Baz Baz is offline
Regards.
Thanks Mando. The fuel lines and Fuel Pressure Regulator went in today. We are working from the rear--- forward.
Baz
Old 12-16-2008, 02:53 AM
AC-460's Avatar
Good to see you having fun with your build bazzy...... roll bars don't look 3 inch
Old 12-16-2008, 03:41 AM
Tenrocca's Avatar
Ive convinced my missus that a dvd is about 8 inches wide.....
Old 12-16-2008, 03:47 AM
And your missus was saying that she plays hoops with the DVD's. and can get 100% of em on "the peg" from 5 mtrs away.
Old 12-17-2008, 12:36 AM
AC-460's Avatar
Barry have you sat the seats in front of the roll bars to see if the roll bar centre is in the centre of the head rest? the roll bars look very close together.....which means the seats must be close together
Old 12-17-2008, 06:48 PM
Baz's Avatar
Baz Baz is offline
Thanks for your interest AC460. My mistake. The roll bars are actually 2.5" diameter with 2" rear stays. I originally ordered 3" from RMC, but have now established that they can't successfully bend the 3" tube without it kinking severely. 2.5" were as thick as I could get and I'm really happy with them. The seats positions have been checked and fit in with the roll bar centres perfectly.I will be posting some more photos shortly.
Baz
Old 12-17-2008, 07:02 PM
Baz's Avatar
Baz Baz is offline
Default Its Been A Busy Week.
Old 12-17-2008, 07:07 PM
Baz's Avatar
Baz Baz is offline
A helpful hint for anyone installing Roll Bar Rear Stays. After the hoops have been positioned, secure a torch inside a section of rubber hose and push that hose up onto the point where the Rear Stay joins onto the Roll Bar Hoop. The light from the torch indicates the exact point where the holes are to be cut through the body for the Rear Stays to be attached to the chassis. You can see this better in the above photo.
Old 12-17-2008, 07:13 PM
Baz's Avatar
Baz Baz is offline
The radiator and cowling in position.
Old 12-17-2008, 10:35 PM
stephen low's Avatar
Looking good Baz, it's good to see someone has time to work on their car!
Not sure if the tiptronic is the same as my BF has but playing with it a few times now in manual selection mode, I'm thankful for the electronic limiter to remind me to change gears after giving it a bootful in first.
I keep on forgetting it's just not like a manual with a clutch which is the reminder to change gears to me anyway.
slowy
Old 12-17-2008, 11:10 PM
AC-460's Avatar
You must have a stutter baz only need to post the photo's once.....
