10-08-2009, 02:31 AM
Sounds great Baz. I was going to use the MB Haartz product but was convinced that what I got was more effective. Not sure, as I have had the former and it was fine. Your sounds brilliant!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-10-2012, 07:27 PM
Mervs roof
I've just been to the trimmer to price up and discuss my soft top.
I've fitted up a hardware kit from a fella who'd got it from Snakebite and didn't end up using it.
Trying to minimise the number of studs on the body. I noticed that yours, Merv, has none along the back.
How did you achieve this?
Peter TUF used a moulding to get a nice neat body fit as he described in previous posts.
Does anyone know if there's one around to fit a Harrison (assuming a DRB won't be the same)
02-10-2012, 09:22 PM
Greg I found that with the liftadot fasteners fitted in the right places along the side, and a thin flat, stainless bar though the back of the hood, it fits perfectly with no leaks or flaps. It fits into the tear drop fitings from the MGB. The underside has felt type material sewn on. Steve here has the moulds for the fiberglass frame on the Harrison if you need you really need those. Let me know if you need some other pics.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Reason: adding
02-10-2012, 11:20 PM
Ahh good idea. I haven't seen that on other cars only all the liftadot posts.
Some xtra photos would be good to show the trimmer thanks. He did Red Garetts car some time back but can't recall all the details. I'll PM you my email address again.
He mentioned stitching in a gutter of sorts to stop the rain dripping in the window opening. Did you have windows made? Warwick mentioned a fixing a post on the front and rear top of the doors and someone else putting a few press type studs on the inside lip of the door top. Seems to me that having the material fixed to the inside of the door would mean water runs inside??
02-10-2012, 11:58 PM
Will do Greg. I have the stitched on window gutter around each side. If you can look at an MG/Sprite hood at the rear you can see the arrangement for the small flat bar. MG heritage have the tear drops cheaply. Will do some pics tomorrow and send them. I also have a design for perspex windows with a frame that can be made to fit any Cobra.
I didn't do windows, as we are making a couple of hardtops at the moment for Harrisons. They should only cost about $200 in when formed, but not trimmed.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-11-2012, 02:52 AM
Zzz
Looks great
Bernie Knight
02-11-2012, 04:55 AM
Hoods are tricky things. The rear angle and the 'bump' (or not) in the middle are things where views vary. I think I have the same bow set up that you have (except mine are 100mm longer on the sides). Play around, as Geof did, with an old sheet to see what you get with the bows up. You have probably done all this anyway. Will send you some pics of the rear stitching tomorrow.
Greg - this shows the liftadots and the tear drops.
Rain channel
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-11-2012, 02:19 PM
Thanks Merv, I'll look forward to the pics.
My stop light poses a problem as it's placed right where I'd like the roof to go, didn't think of softtops back when i was drilling those holes....bugger!
Just another Cobra challenge
02-11-2012, 04:55 PM
Email sent with several pics, including some zip and velcro windows. This is the RHS fitting for the post on the frame. I put a rubber piece around it as there are times when it could slip out when you are putting up the hood and scratch the surrounding paint. Also shown are a few of the liftadots needed (the press studs are for the tonneau which gets a lot of use).
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-13-2012, 02:30 AM
Zzz
merv
The roof looks great and the lines and side profiles are both great - really suit the car.
Bernie Knight
02-13-2012, 02:40 AM
I should use it more Bernie, especially now in the hot weather. I looked at dozens of shapes and setups before I settled on that one. It is important to find a trimmer that has experience with soft tops. Is that GT40 gone yet?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-14-2012, 12:41 AM
Cobra Make, Engine: Drb,5.6 8tb Windsor,TFS heads,Dart Shp,TKO600 ,4link 9in diff.Ford acid rush Paint,convopro wheels.
Hi Greg,
Pretty sure Scott at Venom has the rear mould the right shape for a harrison.....
then Attached to body with Tennax fasteners and the two Mg teardrops, and a steel or alloy bar to reinforce as Merv has Suggested..
You will Also have to consider if you want to use the 1 or 2 piece windscreen header,both with pros and cons...
Peter..
Horsepower sells engines,Torque Breaks 9 inches...
02-16-2012, 03:04 AM
NSW
Baz's Roof and Tonneau Cover
02-17-2012, 03:28 AM
NSW
G'Day Baz,
That roof is spot on..the original ones seem to go up at the back then drop away over the roll bar....who's your trimmer. I live close enough.
02-18-2012, 03:30 PM
NSW
Originally Posted by Rob. Smith
G'Day Baz,
Hi Rob,
Unfortunately, my trimmer, Mick Talbot has moved to Brewarrina in western NSW. His partner is a Paramedic and was posted there for 2 years so he went with her about 6 months ago. He also did my consul. A fabulous trimmer. For what its worth, his mobile No is 0432405562.
Baz
02-18-2012, 08:45 PM
Zzz
Merv
Still have the GT40.
Was driving around in it the other day. Keep talking myself out of selling it.
A little interest in it...
Bernie Knight
