Old 04-10-2009, 06:17 PM
Tenrocca's Avatar
Originally Posted by WKB View Post
Roger I had a look at the rear of the mini, but couldn't see where the reverse light is.
It has changed location in the later models - here is an earlier model with the reverse light just above the exhaust. In the later models this is one of the red fog\vision light things
Old 04-11-2009, 05:08 AM
Originally Posted by Mando View Post
The best looking 3rd brake light Ive seen is on the Nissan 380Z convertible. I think the size and look is perfect.
Regards.
Like this ?
Old 04-11-2009, 07:09 AM
Towmaster's Avatar
Default Mini reversing lights..
Warren,
This is my car as fitted with two of the late model mini reversing lights... ( i hope this photo works....)
They are off the first of the late model minis, the later ie 2007 2008 etc had a red light at the back and not the clear ones...
I think they were about $20 each....
Towmaster..
Old 09-28-2010, 06:49 AM
boxhead's Avatar
Hi again Warren, how did you go regarding revese lights?
What did you use and do you have a pic?
Also how did you go regarding the high mount brake light?
Cruising in 5th
Old 09-28-2010, 11:28 PM
WKB's Avatar
WKB WKB is offline
I could not find a reverse light that would not look like an add on. I eventually purchased an ADR approved LED generic light and attached it to mess under the back of the car. The only problem it is back to far to meet the ADR. I am in the process of moving it more towards the back so it will comply.
The high mount stop light is the one Classic Revival make. It took a bit to make it fit the curve of the 540 boot as it is flatter than the AC boot.
Although I am not 100% happy with it, it looks OK and I got away from the "kit car look" the hella high mount stop lights give.
Warren
Old 09-28-2010, 11:40 PM
boxhead's Avatar
Thanks again Warren.
The "roll hoops" on the car I am building have been removed and he has had Chrome moly ones made that bolt in and down to the rear subframe, I will get some pics when I start on the car.
They are a reproduction (look the same) as the ones originally fitted.
Cruising in 5th
Old 09-29-2010, 01:09 AM
Cobra Make, Engine: Classic Revival Kobra,LS7 427
Ive made both indicaters my reverse lights. Just like a HQ Holden the ADR states can be amber or white lense
