Old 03-05-2009, 04:02 AM
pcoghlan's Avatar
Club Cobra Member
Cobra Make, Engine: Gardner Douglas 427 Euro
Default LSD oil for BTR LSD
Posting in here as I 'think' the BTR LSD is more popular in your neck of the woods!
I have been variously told that the following 'maybe' right. I would be interested to know if there is a recommended spec or whether either of these is suitable.
Castrol SAF-XJ
Mobil SHC80W140
Valvoline GL-5 LS
Paul
Just relocated from Ireland to the US and brought my Cobra with me...
Old 03-05-2009, 05:16 AM
Clois Harlan's Avatar
FWIW Paul I have very good luck with both Castroil and Valvoline and others I know seem to think the Mobil is the best oil out right now. I don't think you can go wrong with any of your choices.
Clois
"Let's roll"
"Be part of Something Good
Old 03-05-2009, 05:23 AM
pcoghlan's Avatar
Club Cobra Member
Thanks Clois, I will run to NAPA this morning to see what they have.
Wasn't sure if the BTR had any special requirements or need for additives.
Paul
Old 03-05-2009, 07:30 AM
pcoghlan's Avatar
Club Cobra Member
Just a thought. Anyone know how much I will need?
Paul
Old 03-09-2009, 03:03 AM
Gav's Avatar
Gav Gav is offline
I just used a Mobil diff oil to suit late model LSD's.
Remember to add the oil additive to your diff oil. It comes in a 100ml bottle.
The rear end will feel as though there is a CV joint about to fail if you don't.
I may or may not be speaking from experience.
The extra set of drive shafts I own prove it!
Powered by Cu
Old 03-09-2009, 03:40 AM
pcoghlan's Avatar
Club Cobra Member
Thanks Gav, which additive?
I now have it on good authority from a TVR mechanic (TVRs use the BTR) in the UK that they use Mobil SHC 80W 140 ID for both the BTR LSD and Hydratrak.
http://www.mobil.com/Australia-Engli...ube_SHC_ID.asp
He makes no mention of additive though?
Paul
