Old 04-09-2009, 08:07 PM
byroncobra's Avatar
Default Throttle body position
I had a thought on my issue with the engine/bonnet clearance.
If I turn the throttle body 90 degrees the throttle posn indicator, which is the main culprit fouling the bonnet, is then out of the way.
It makes setting up the throttle cable a bit tricky and moves the idle speed control solenoid on its' side, just clearing the rocker cover, but I can at least get the bonnet almost closed.
Can you see any problem running it this way with the butterfly horizontal etc?
Greg
Old 04-10-2009, 12:17 AM
Merv and Sharon's Avatar
Any chance of a pic Gregg? In principle it should be OK, I think. Throttle cable could go over a small grooved 'wheel' or quadrant (see clutch cable on Mustang catelog).
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 04-10-2009, 02:21 AM
PANAVIA's Avatar
what about a aluminum spacer that angles the TB down a bit instead of 90 rotation you tilt it down 20 degrees >?
