06-29-2009, 06:49 PM
NT
Cobra Make, Engine: King Cobra, QLD - 347 windsor
Help finding 4.5 inch stainless tube
Hi Guys,
I am trying to source 4.5 inch stainless tube for my sidepipes but most major suppliers are telling me there is no such thing.
Does anyone know of an Australian supplier.
Hogster
06-29-2009, 08:21 PM
cannot help with an Australian supplier but they are full of dung when they say no such thing
http://www.mcmaster.com/#stainless-steel-tubing/=2ja8uc
fred
06-29-2009, 09:38 PM
Md
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
Global Technology & Engineering has 4.5" diameter 304 SS tubing (.120" wall thickness). Here's a link http://www.globaltecheng.com/Product...idproduct=4556
They list the price at $38.00 and will ship via UPS but I don't know if it's economically practical to ship overseas.
They do have a form on their web site that allows you to request a quotation.
*** OF GREAT WORTH *** And JESUS asked again, The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the 57 Thunderbird, the 63 Stingray, the XKE, and bought the dark blue 427 Cobra. The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
06-30-2009, 12:53 AM
NT
Found some
Thanks for the responses.
Geordi Stainless sell what I am after, listed as stainless pipe.
It is 114.3 outside diameter with a 3mm wall thickness. $110-00 per meter.
They list it as 4 inch shed tin pipe???
Anyway all good,
Hogster
06-30-2009, 02:21 AM
Vic
Cobra Make, Engine: Classic Revival.
You could try Darren down here in Victoria.
I used 4 inch at $75 per meter but he said he could perhaps roll some to make 4.5 inch in stainless at around $120 per meter.
http://www.darrendifilippo.com.au/index.html
Cheers, Dale.
06-30-2009, 05:40 AM
Member of the north
Cobra Make, Engine: A Cobra
Hey, thanks for posting the sites.
I was looling for SS in 4.
06-30-2009, 05:55 AM
4.5" 3mm wall, that should keep the c of g low.
06-30-2009, 06:44 AM
What do side pipes like that weigh?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
06-30-2009, 02:46 PM
CO
check with performance diesel shops, that stuffs pretty standard for them. SOmetimes they even use 5" and 6" SS pipe. I'd bet they can also supply the turn outs.
06-30-2009, 05:06 PM
IL
Not Aussie but here's some .065 wall. You'd need girders to support 4.5 x .125 wall sidepipes.
http://www.burnsstainless.com/304tub...raight304.html
06-30-2009, 08:26 PM
NT
Side pipe weight...
Dont know yet regards what they will weigh. They will be relatively heavy though. Stainless internals as well.
I will have them bracket supported in a couple of places and bolted to the chassis.
They will end up being copies of Aussie Mikes setup, basically with interchangeable internals, cats and quiet in one set and no cats and larger diameter in the other set. Rego Vs After Rego
The 4.5 inch was difficult to find and is not polished, 4 or 5 inch polished stainless is everywhere.
Regards
Hogster
07-05-2009, 06:25 PM
VIC
Hi Hogster,
I've been away overseas for a bit so haven't had much time to get on the forum lately.
I've bought a fair bit of stainless tube from Tubesales down here in Melbourne. I've bought 4" from them in the past so there's a good chance they have 4.5"
Here's their web page: http://www.tubesales.com.au/index.htm
3mm wall is way overkill. Why so thick? They are going to weigh a ton.
Mike Murphy
Melbourne Australia
07-05-2009, 08:36 PM
VIC
I like the way Tubesales categorise the sizing as 'Young Buggers' or 'Old Buggers' for metric or imperial measurement
LB
07-06-2009, 10:56 PM
NT
Tubesales dont have it.
Yes guys the 3mm stuff is too heavy, it looks like I will have to have it cut and welded from 5 inch with 1.6mm wall, or have it rolled and welded.
Either way it's going to cost me.
I have chased truck exhaust places, tube sales, atlas, georgi and all manner of other stainless suppliers and I have not been able to source 4.5 inch in Oz.
I am still hoping somebody will know a place that stock it.
Hogster
07-06-2009, 11:12 PM
VIC
If you haven't got access to a set of slip rolls I reckon cutting an re-welding 5" tube would be pretty easy. Do you have access to a plasma cutter?
I'd clamp a straight edge along it and slice a section the right width out with the plasma cutter. Next I'd turn up a couple of plugs from aluminum that are the right OD to go inside a 4.5" tube. Put one in each end and clamp the tube down onto them with some big hose clamps. Add a few extra clamps along the length of the tube to close up the gap. Tack weld at several points along the seam. Get a long length of 2" round bar or heavy pipe clamped in the vice. Slip the tube over it and use it as a dolly with a hammer to work the metal round at the seam as needed. I don't reckon it'll take much. Weld the seam along it's entire length. Job's done.
Mike Murphy
Melbourne Australia
