| 29 |
09-08-2009, 04:23 PM
Strong Glue
Does anyone know of an adhesive I could use to stick the standard aluminum pedals you find on cobra's onto the steel plates on my arms? I have ground the lug from the back of the pedal so it's one thickness all the way, and I intend grinding of the paint from the arms.
Regards.
Mando
09-08-2009, 04:34 PM
Highly recommend this Mando:
http://www.itw-devcon.com.au/index.p...=75&Itemid=161
drill a few small holes in the steel pedal and countersink at the back of the pedal so you have a kind of rivet effect.
09-08-2009, 04:46 PM
NT
Hi there Mando, I did not use glue when attaching mine.
I cut the metal pedal pads off and fitted the pivoting AC pedals, although not finished in the attached pics, I later fitted a longer bolt through the pedal and fitted a coiled spring that pushes between the upper part of pedal and the arm.
Sadly I do not have a pic of it.
But I think Aussie Mike did something similar.
Cruising in 5th
09-08-2009, 04:50 PM
DO NOT use any sort of adhesive for this. It is a safety item that is too important to risk a bonding failure. DON'T DO IT. Attach with countersunk machine screws or better yet as the photos illustrate.
09-08-2009, 05:11 PM
Thanks Rebel 1, looks like thats the stuff I need.
Hi Boxhead, Ive thought about using your method many times but I cut the pedals, welded the plates and painted them years ago and at this stage can't be bothered.
Rick, your absolutely right, I'll glue them for now and get some screws into the back of them when the cars off getting painted.
Regards.
Mando
09-08-2009, 05:33 PM
NSW
Cobra Make, Engine: G Force, Motorsport Boss 302 (LPG).
I have to agree with this, I fitted the Sparco ones and used the HT countersunk machine screws supplied, its a key Safety feature. just my 2 cents.
Terry.
09-08-2009, 07:23 PM
VIC
Hi Mando,
I also would advise against using glue. If you don't want to use a pivot setup then I would drill the backs of the pedals and rivet them to the steel plate. Alternatively you could drill and tap them from the back.
The last thing you want is your pedal tread coming loose when you jump on the brake.
Here's a pic of the spring loaded setup I did.
The idea is that the pedal tread can pivot under the ball of your foot and keep it flat. With the low seating position in relation to the pedals the clutch pedal can get to an uncomfortable angle at the end of its throw. The pivoting treads fix this. I wanted the treads to pivot freely but sit level and not rattle when relaxed so I spring loaded them.
They are comfee to use and have good feel.
Mike Murphy
Melbourne Australia
09-08-2009, 09:33 PM
Boxhead, Mike, I really like the idea of the pedals pivoting. If I go down that route now I'll need to extend the length of the arms before attaching pedals. As I said in my last post it may be a job I'll tackle when the cars at the painter.
Regards.
Mando
09-10-2009, 02:09 AM
vic
Honestly Mike, is there anything on your car you havn't modified?
Powered by Cu
09-10-2009, 02:16 AM
Show us your pedals Gav! Go on I dare you.
Regards.
Mando
09-10-2009, 02:52 AM
Do these meet ADRs?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
09-10-2009, 03:12 AM
If that question is directed at me Merv, I'd have to say probably not. Screws through the rear into the aluminum should make them a lot stronger.
Regards.
Mando
09-10-2009, 04:16 AM
I seem to recall that one needs, "rubber pedals fitted and in good condition" but that was a QT requirement and therefore a roadworthy aspect at any time.
But the AC ones look good and my WRC STI had metal pedals!
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
09-10-2009, 04:36 AM
Member of the north
Cobra Make, Engine: A Cobra
You all do nice work.
No glue, screws from behind.
Please don't run any wiring down by your feet. You will regret it later.
09-10-2009, 05:51 AM
Trularin, the loom you can see in my photo is the dash loom before I strapped it onto the dash hoop.
Regards.
Mando
09-10-2009, 06:58 AM
Member of the north
You do great work, I thought maybe, but you never know.
09-10-2009, 07:44 AM
VIC
Originally Posted by Merv and Sharon
Do these meet ADRs?
Merv
My car went through engineering and rego in Victoria with this pedal setup as you see it.
I think the rules have been relaxed in recent years as there are a number of production cars appearing with metal pedals. The AC pedals still have rubber grips with those grommets through them.
Michael
Mike Murphy
Melbourne Australia
09-10-2009, 08:47 AM
ID
Cobra Make, Engine: Contemporary Classics 427 SC, 427 sideoiler
Aussie Mike, What brand of pivoting pedals did you use? I really like the spring clips you added.
09-12-2009, 03:00 PM
Zzz
CCX 33239
I have similiar pedals and purchased them from Finishline. On the left side of this forum.
I used a hardware type spring similiar to Aussie Mike. No doubt Aussie Mike would have made his springs.
 ..Shelby would never have one a race if Aussie Mike was on his team as they would still be building the Cobra or rebuilding it..
Sorry Mike just had to say that....
Bernie Knight
09-13-2009, 05:03 PM
ID
BMK,
Thanks. I'm going to be redoing the entire pedal and master cylinder setup this winter and new pedal pads seemed to be in order. I had pretty much decided on the Finishline pedals and this convinced me.
Bob McFarland
