Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-09-2010, 05:46 PM
Cobra Make, Engine: B&B 351w w/mild build, Silver Blk Stripes
Default Headers for a B&B with a 427w
Bryan,
I have a 2002 B&B cobra (roadster) and am looking to put a KC 427w in the engine bay. I currently have the small 1 1/2 or 1 5/8 inch headers on a
351w. Do you folks make a larger diameter header for the above 427w engine with AFR heads.
Thanks,
Mike
Old 02-09-2010, 07:36 PM
Cobra Make, Engine: B+B 351w #112
Give Bryan a call. I think larger diameter header tubes are available. Jim
Old 02-09-2010, 08:09 PM
carbon777's Avatar
Cobra Make, Engine: Hurricane
I believe the gains would be small plus your going to loose some bottom end torque. To inrease to larger diameter headers usually requires adapter plates and spun offset bolt pattern. A good source for these is Kooks ..... but they are pricey and kinda a pain but they have them. Also remember it will require their gaskets always....... Just thought you should know ..... did this myself a few years ago. Went to 1 7/8 primary tubes. - Carbon777
"If things seem under control your just not going fast enough" Mario Andretti
