Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 07-26-2010, 03:00 PM
ndpace's Avatar
Cobra Make, Engine: B&B with Motorsport Crate 302
Default bullet driver side mirror
I do not know if it came from B&B, but I have a bullet style mirrir monted on the driver side front fender just in front of the door, but I can not get it to adjust and see anything other than the ground right next to me. Is there some trick I am missing?
Thanks, Jim
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
01 F350 Crew Cab V10
Old 07-26-2010, 06:51 PM
Zoom This's Avatar
Try to loosen the back screw holding the assembly together. After it is aimed, go to a Pep Boys or Grand Auto etc. and buy a convex mirror that will attach to your flat face mirror with double sided tape. Mine's a perfect fit and you can see cars in your blind spot easily.
Old 07-26-2010, 06:53 PM
Senior ClubCobra Member
I can't figure out how it is buggered up. Post a picture.
Old 07-27-2010, 03:40 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I had the same problem. When I finally got it to adjust, all I could see was the rear fender staring back at me. I relocated mine to the windshield and it is MUCH better.
Old 07-27-2010, 07:40 AM
Cobra Make, Engine: SPO 2644 Roush 427R
Randy at Cobra Valley sells a mirror insert. I took the front nylon insert ring out pressed the insert mirror over the top of the original. Re-installed the nylon ring and it works great... Be careful, objects are a lot closer than they appear...
