Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 08-21-2011, 11:38 AM
Cobra Make, Engine: B&B, 428 FE, toploader
Default Hood latch parts
The "J" shaped piece on the hood latch with the screw in it that locks into the body fell off of one of my latches. Does anyone know where I can get a replacement part? Thanks, Chas
Old 08-21-2011, 12:06 PM
FWB's Avatar
FWB FWB is offline
most of those aren't automotive specific, they are just utility type cams for cam latches
for instance, cage doors on delivery vans have them separating the passenger from the cargo area. a good hardware store, tractor supply, etc......
Fred B
Old 08-21-2011, 01:46 PM
Great idea. I will Tractor Supply a shot on Tuesday when I am there. Thanks.
Old 08-21-2011, 02:01 PM
Rick Parker's Avatar
Very popular for use on the rear window locks on Camper shells for pickups.
Old 08-21-2011, 02:48 PM
Leecbr's Avatar
Cobra Make, Engine: Factory Five MK4 427 roadster
Chas,
I used a flat screw and washer with some lock tight to keep the screw from loosening. The washer was placed in the space between the hood rod and the " j " shaped hood latch part. I put some jb weld/quick steel at the bottom of the long rod to keep them from sliding off. Just a back up.. I haven't had a problem since.
Old 08-21-2011, 04:14 PM
Rick, thanks for the backup source.
Leecbr, the JB weld is great idea. I guess if I used that I wouldn't be looking for a replacement part.
Again, thanks everyone. Chas
Old 08-21-2011, 04:57 PM
FWB's Avatar
FWB FWB is offline
once you've established where it ends up on the shaft, drill a drill point into the shaft for the screw to nest into, might keep it there until you realize it needs to be tightened again.
Fred B
