09-10-2012, 07:49 PM
ny
Cobra Make, Engine: b&b
windshield angle
Am i dreaming or are the later cars coming with the windshield at more of an angle. my 97 b&b seems to be more vertical. The cars on the b&b site even seem more laid back.
09-10-2012, 08:05 PM
AL
what degree of angle do you have?
Dwight
09-10-2012, 09:25 PM
Ut
Cobra Make, Engine: 66 Cobra
I think I put mine at about 37-38 deg. I read on earlier threads that B&Bs were supposed to be 36-37 inches from the center rear cowl deck to the top edge of the windshield. I know Kirkhams put their's at 45 deg. I tried that but the seal just does not set right.
09-11-2012, 07:50 AM
I replaced the bottom seal and increased the angle of mine and it seems to seal good. The problem I had was the paint was worn under the seal from the old angle, so I suggest getting it right before paint. I originally had mine at about 35 deg so that I would not be looking through the frame while driving ( I'm a larger guy), but didn't like the look so after a year or so, I changed mine. I like the look better at the steeper angle and have adjusted to the view.
08-11-2013, 09:05 PM
Ouch Ouch Hot Sand
Okay, its been "MANY" years since I've taken any math in school and I admit I've forgot more than I now know, sooooooooooooooo, someone help me out here and tell me "How do I figure my Windshield Angle?????
/l
/ l
/ l
/ l
/____ l
I have the three measurements shown above, which are 8.75 for bottom leg, 12.25 for back straight leg, and 15.25 for the angle that would be the windshield.
08-11-2013, 09:48 PM
Accurate, so to speak, should be about 42 to 43 degrees as measured on a level car, at the center of the windscreen. If that's what your after anyway.
Alba gu brąth
08-12-2013, 12:16 PM
/l
/ l
/ l
/ l
/____ l
Sin(x) = 8.75/15.25 or Sin(x) = .57377 or 35deg
Try to shoot for the bottom to be almost the same as the back straight. (45 deg).
08-12-2013, 02:51 PM
here this will be easier to understand
sin (Deg)= opposite side/ hypotenuse
cos(deg)= adjacent side/ hypotenuse
tan(deg)= opposite/adjacent sides
deg=degrees
opposite side= the length of the side opposite the angle your finding
adjacent side= " " " " " adjacent to the angle your finding
hypotenuse= the length of the side opposite the right angle
so plug in the sides to the formula get the answer to the division and then hit the sin^-1 key or the cos^-1 key etc..... to get the angle
or post the lengths and i'll tell you what angle you have
Fred B
08-12-2013, 02:56 PM
based on the lengths you have your two angles are 54.46 and 35.53
i used 12.25 as the rise and 8.75 as the run......the top angle is the 35.53 and the bottom angle is the 54.46
Fred B
08-12-2013, 07:50 PM
I just use the angle finder on my iPhone.
Alba gu brąth
08-12-2013, 08:17 PM
Ouch Ouch Hot Sand
FWB, what do you mean by the top and bottom angles? Are you referring to inside and outside of the windshield?
08-12-2013, 08:42 PM
 Earl, your in essence making a triangle with the windshield, i made the dotted line the 12 inch dimension you provided the bottom was the 8 inches.......
Fred B
08-14-2013, 06:42 PM
Ouch Ouch Hot Sand
Well, I used a electronic prop protractor and it shows 51.2 degrees. I'm gonna have to work on it this weekend and see if I can get it closer to the 45 degrees
08-14-2013, 08:02 PM
tx
Just go to the hardware store and buy a degree finder. Just put it on the outside of the windshield and read what it says. Or, set your car outside and just look at it from the side and adjust your windshield to where it looks the coolest.
" It ain't no big deal"
08-14-2013, 08:07 PM
Ouch Ouch Hot Sand
The electronic prop protractor is a degree finder and yea, I thought about the looking from the side idea.......may try it
08-16-2013, 11:37 AM
When I corrected mine after driving it for a few years, the bottom seal had damaged the paint. I had to repaint the section under the old windshield location.
