Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 01-19-2014, 06:02 PM
Cobra Make, Engine: b&b
Send a message via AIM to erudolph
Default frame smiley face
Hi guys, my 97 frame doesn't have the smiley face for trans/yoke clearence. does any of you have your frame handy to measure the length and width of that portion of frame. its the center of the x-member. thanks ed
Old 01-21-2014, 05:54 AM
lnfletcher's Avatar
I guess I'm unsure of what your needing. I can try to get it if I know what to look for.
Old 01-21-2014, 07:33 PM
Default smiley face
Larry, I have used your pictures as a reference, thanks. the portion of frame i need measured is rite under the trans at the yoke, its the depression in the x member. i need the width of the depression and the length so i can pre-cut the parts before cutting the frame. thanks ed
Old 01-22-2014, 07:49 AM
Clois Harlan's Avatar
You might want to call Barry McGill, for the life of me I do not know what you need. Barry McGill can be reached at 417-472-7848. I am sure he will know exactly what you are talking about.
Clois
"Let's roll"
"Be part of Something Good
Old 01-22-2014, 09:23 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
It's 4 3/4" - 4 7/8" long, front to rear, and 1 1/4" down on the inside. It's a section of a piece of pipe.
Added: That's down from the X bracing that is made of 2X3, that is flush with the bottom of the 2x4 frame. Making the X member 1" lower than the top of the 4" frame. In case you need the length of X members where it attaches to the frame, it is 19" long point to long point.
So with the 1 1/4" plus the 2x3 being 1" down it gives you 2 1/4" from the top of the 2x4 frame for the .
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 01-22-2014, 07:34 PM
Thats it, i think i have what i need to continue but rite now its in the 30s' in the garage. I'll put the heat on when this below 0 weather breaks. thanks
