Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 04-30-2014, 06:41 AM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Default B&B Dash Removal
Thinking about swapping the existing Faria gauges out with a new Stewart Warner set. My B&B dash has 3 mounting points that are covered by a very tight fitting round plastic trim button. Any suggestions on the best way to remove these and the associated dash mounting hardware is appreciated.
Old 05-05-2014, 05:00 AM
lnfletcher's Avatar
I removed the steering wheel, then nuts on each end of the dash and at top with a 1/2" or 9/16" socket I believe. Then depending on tail/no tail, remove the rest. This allows me to drop the dash and do whatever I need. It sounds like yours may have been mounted differently.
This shows the "standard" mount points.
