Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 02-02-2002, 12:28 PM
jams's Avatar
Cobra Make, Engine: B & B
Default Bolt on Motor Mounts
Hi,
Has anyone out there bolted their motor mounts to the frame? If so, did you use 3/8 or 1/2in. bolts?
Thanks
Paul
Old 02-03-2002, 12:16 PM
Cobra Make, Engine: B+B 351w #112
Hard to tell what size it is after the motor is in. Looks like half inch. I took my rubber motor mount to the hardware store and got the largest grade 8 bolt that would fit. Jim
Old 02-03-2002, 04:07 PM
Cobra Make, Engine: B&B 351W
Exclamation Motor Mounts
I thought that might be the way to go originally but am very glad I welded them, the measurements B&B gave me where right on the nose, I did install the Eng. on the mounts and lowered the Eng. in to make sure the header pipes fit the side pipes straight and the front pulleys cleared the cross member. If you can find a way to weld I would highly recommend it.
