Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 03-14-2002, 08:25 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Attaching Dash Material
I feel like I am the only guy asking questions here. What did you guys use to attach your dash material? Also, did anyone mount their cut-off switch on the dash? If so, where at? Any pictures?
Appreciate all of the help,
Tom
Old 03-14-2002, 05:06 PM
Cobra Make, Engine: B+B 351w #112
Go ahead and keep asking. Gives me something to think about. Going to have surgery on my shoulder on the 25th. Off of work for 2 months. As for the dash I can't help you. I made a dash out of mahagony. It matches the steering wheel. Any other questions keep asking!!!!!!!!! Jim
Old 03-15-2002, 08:42 AM
jams's Avatar
Cobra Make, Engine: B & B
I used 3-M Spray adhesive. It worked very well. They have a regular strength and an extra strength. I used the extra strength. It was probably the same thing in a different package for 2 dollars more. It works like contact adhesive. Spray both sides wait a while and stick. Not much room for error. I know I was very tense when I did it.
Just be careful the spray seems to find its way all over the place.
Good luck
Here is a link to some pictures that might help. There are some of the completed dash.
http://www.jamswebdesign.com/cobra2/
Old 03-16-2002, 06:58 AM
I have the black dash material that I didn't use if you want it. Jim
Old 03-16-2002, 07:58 AM
Gee the web site looks similar to a cobra manufactures site, is your snake from the same manufacture?
Draco
Old 03-16-2002, 09:15 AM
Okiesnake's Avatar
Cobra Make, Engine: Unique 427SC, 351W
If you get, or rather when you get the spray adhesive on stuff you where you don't want it, use ordinary charcoal lighter fluid on a rag to remove it. It won't hurt vinyl, paint or carpet. I’m not sure about leather but I doubt that it would harm leather. Works like magic!
Okiesnake
Old 03-16-2002, 09:22 AM
The medium strength 3M from Track, Pep Boys, etc., will work fine. Spray both sides, let dry tack free, then stick. Now, for dashboards, there's one more step. Where the vinyl folds around the back of the dash, use DAP or Weldwood contact adhesive (Hardware store, Home Depot, Lowes). It's used for laminates and kitchen countertops. This stufff will hold the overlap in place, wheras, the 3M will not. If you decide to get fancy with a veneer (constantines.com), put the veneer over plywood with the Weldwood. Use screws, under the veneer, to attach the inlay through the dash. Cutout the foam backing under the vinyl dash for the inlay. Really looks plush.
