Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-24-2002, 02:16 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Battery Size
I am getting close to test firing the engine. Can anyone recommend a battery?
Old 03-24-2002, 02:42 PM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Go with an Optima type of battery with no leaks and or spills.
TURK
OBAMA IN in 2012
Old 03-24-2002, 03:30 PM
OhBuoy....Turk has it right on the Optima battery, as for size if you have not alot of accessories then go for there Red Top it is side post or dual post
Have fun! Ken
Old 03-25-2002, 06:22 AM
jams's Avatar
Cobra Make, Engine: B & B
Optima Battery is the way to go. Expensive but worth it.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 03-25-2002, 09:01 AM
Cobra Make, Engine: ERA Cobra #273, 427 S/O, ERA GT-40 #2057, Excalibur Cobra.
Thumbs up Bttery
OHBOY,
SEVERAL PEOPLE HAVE HAD PROBLEMS WITH THE OPTIMA BATTERIES - INCLUDING ME. MOST OF THE PROBLEMS SEEM TO COME FROM ONE OF TWO CONDITIONS.
1. LETTING THE BATTERY GO TO NEAR DEPLETION - IT WON'T ALWAYS FULLY RE-CHARGE. INCLUDING THE "DEEP DISCHARGE MARINE TYPE BATTERY".
2. JUST THE OPPOSITE: LEAVING IT ON A "TRICKLE CHARGER".
I POWER MY TRAILER WITH A BANK OF "YELLOW-TOP" OPPTIMA BATTERIES. I HAD ONE BATTERY NOT HOLD A CHARGE AFTER ABOUT THREE MONTHS. THE DEALER REPLACED IT WITHOUT ANY ARGUEMENT. HE COMMENTED TO HIS HELPER WHO CAME TO THE COUNTER TO CARRY THE BATTERY AWAY, "YEAH, WE GOT ANOTHER ONE". AFTER ENGAGING THE COUNTER MAN IN SOME FRIENDLY CONVERSATION HE CONFIDED THAT IT "HAPPENS ALL THE TIME WITH THOSE OPTIMAS". NOW - I SERIOUSLY DOUBT THE "ALL THE TIME" STATEMENT BUT APPARENTLY IT'S NOT UNCOMMON EITHER.
I DECIDED NOT TO USE AN OPTIMA BATTERY IN MY ERA COBRA. I WENT WITH AN "ODDESEY BATTERY" INSTEAD. ODDESEY USES A TECHNOLOGY ABOUT ONE OR TWO STEPS BEYOND GELL CELL OR RING CELL TECHNOLOGY. THE BATTERY IS CONSIDERABLY SMALLER (ALTHOUGH IT WEIGHS ABOUT THE SAME) BUT IT DELIVERS THE HIGHEST OUPTPUT AMPERAGE IN THE INDUSTRY. ADDITIONALLY, IT DOESN'T SEEM TO CARE WHETHER IT'S DEEP CYCLED OR LEFT ON A MINI CHARGER FOREVER. ALSO - VERY IMPORTANT POINT HERE - THERE IS "NO LIQUID OR GELATINOUS SUBSTANCE" INSIDE. IT IS COMPLETELY SOLID. JUST BECAUSE A BATTERY IS "SEALED" DOESN'T MEAN THAT IT WONT LEAK. ESPECIALLY IN A CRASH.
I SUGGEST THAT YOU CHECK OUT THE ODDESEY BEFORE YOU DROP SOME BIG BUCKS ON ANY BATTERY. AS I RECALL, THE ODDESEY WAS ONLY A FEW BUCKS MORE THAN THE OPTIMA.
Y'ALL HAVE A REALLY GREAT DAY,
BLACKJACK
It's impossible to make anything FOOLPROOF - - Because FOOLS are so ingenious.
Old 04-03-2002, 02:28 AM
Cobra Make, Engine: B&B 351W
Go with what fits and works good for the size cranking amps you need, I cant see powering to many accessories in a cobra, and you have plenty of room back there, after you put the side wall up that covers it you will never see it again.
Good luck.
