Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
February 2026
Old 06-01-2002, 08:09 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default E-Brake Handle Mounting
I am trying to mount my e-brake. I drilled the holes in the braket prior to putting the fiberglass on. I had to extend the rod about 3" to reach the cables. After doing so, the mount wants to bend. Another member had the same problem. I put the fiberglass on and was going to see how it worked with that on. Now, I am confused. Does the handle mount over th fiberglass? Between the mount and the fiberglass? It looks like I need to cut into the glass to mount the handle, does this seem right? I saw some patch work in this area on someones build site, so I am sure that I do need to cut in, but want to make sure. What are other's experiences with this?
Thanks for the input,
Tom
Old 06-03-2002, 06:52 AM
jams's Avatar
Cobra Make, Engine: B & B
Hi,
You were probably referring to my site in your message. I will list the address again if you need it. I took some pictures of the e-brake install. The way you see it is the way B&B installed it. It works great! I didn't have to touch a thing. Good luck
Jim
http://www.jamswebdesign.com/cobra2/
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
