Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 07-16-2002, 03:50 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Firewall finishing
I posted this question before, but figured I will go for it again. What did everyone use on their firewall? I am contemplating truck bed liner or flat black paint. I am open to ideas.
Old 07-16-2002, 06:35 AM
Default Hi
I thought long and hard about what to do with the firewall in my car. I ended up taking the painters advice and having him fill any gaps or holes that weren't going to be used and then painting it the same color as the body but taking the shine out of it by adding a chemical that makes it more like a "Satin". Came out very nice and looks clean.
Bob
Johnex Cobra, Buick V6
Old 07-16-2002, 09:12 AM
Ron61's Avatar
Default Re firewall
I used Thermo-Tec on mine. It doesn't look bad and provides excellent heat shielding. I also used it to shield my brake and gas lines anywhere they are close to a header or exhaust pipe. It will also help a little with noise but there are better noise insulation materials available.
Ron61
Ron Widener
Old 07-16-2002, 09:30 AM
Gordon Claunch's Avatar
I did my firewall, footboxes and wheel wells in aluminum, turned out very nice
Gordon Claunch
If you can't afford what you want to buy, pick up a book and learn how to make it.
Old 07-16-2002, 10:38 AM
Gordan,how much did you pay for the aluminum treatment and who did it? chuck
Old 07-16-2002, 11:01 AM
It is strictly for cosmetics, it is very thin rolled aluminum, since I did not need it for ridgitity, I work at a oil refinery and got it from the pipe insulators, it is 3 feet wide and 100 feet long, my friend Dennis and I split it, we got it free but you could by it from an insulator for about $135.00 a roll, I glued it on, and used some small screws in some parts, John Mcmahon gave me the idea to use wd40 and a scotch brite pad, then I used a por 15 clear coat, I think it turned out great!! you can see a little bit of it in my gallery.
Gordon Claunch
Old 07-16-2002, 05:49 PM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Post
We use a semi-gloss black for small touch ups. It's almost an identical match for the black gel coat.
Nonconformist. Can't handle a real job.
