Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 09-16-2002, 10:36 AM
jams's Avatar
Cobra Make, Engine: B & B
Default Car Radio Speakers
Hi,
I was thinking of installing a radio in my B&B. I have read some other threads regarding this but I wanted to get some first hand experience from someone who has a B & B with a radio.
Where is the best place to install the radio?
Where is the best place to install speakers?
What size speakers did you use?
Old 09-19-2002, 04:16 PM
GREENSNAKE's Avatar
Default Radio (((JAM MAN)))
HEY JAMS! Do you have the Dash that goes down to meet the Tunnel? If so i put mine there bout 3 or 4 inches from the bottom on the dash perfect spot for it and i put the speakers right behind my right hand shoulder and one on the left side of the passenger shoulder perfect spot and went to Advance auto parts store picked up a flat antenna that fits bhind the dash you put that on the square tube support behind the dash you'll be happy withit. And also i used the 5.250 speakers.I will get pictures if you need them!Take care (greensnake) (Lonny)
Old 09-20-2002, 11:04 AM
jams's Avatar
My dash goes all the way down to the tunnel. If you could post or e-mail a few pictures of you speaker locations that would be great.
If you want to send them via e-mail here is my address: jdolan2726@aol.com
Thanks agian
Old 06-23-2003, 11:53 AM
i have been thinking about this too. get speakers that are separate woofer and tweeter components. go with 5.25 to 6" subs behind your head with a tweeter on the outside and then if you have space on the dash add a small 3-4" sub in dash on driver and pass side with tweeters mounted in corners. that would be my ideal set up. dont forget a small two channel amp mounted in trunk. just not enough power in a head unit to run speakers proparly. i have the same set up in my nissan and it has plenty of bass and highs for a low cost rig. dont need to jar any teeth free.
