Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-18-2002, 09:24 AM
jams's Avatar
Cobra Make, Engine: B & B
Default Hold That Trunk Up
Hi,
What have most of you used to hold up your trunk(Prop rod, etc.) I figured after having it close on my head a few time it's time to do something.
Jim
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 10-18-2002, 10:14 AM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Talking
What'sa matter Jim? Third hand's in the shop? Sorry, had to say it. E-mail Bryan at the shop to send you a picture of our trunk prop rods. Nothing electric or real high tech. Just a bracket, swivel and rod with a hole in the hinge arm. We make them right here in the fab. dep't.
Nonconformist. Can't handle a real job.
Old 10-18-2002, 10:37 AM
Excaliburs use gas shocks for the hood and the trunk. I like it!
Ernie
Old 10-18-2002, 11:55 AM
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
You can also use an OEM Corvette trunk prop from a 60's or 70's vette. Not too expensive and works well. They're the slide and latch type. When you lift up, it stays where its put and to lower just raise it a fraction and down it goes. Simple to install too.
Good part is that it looks factory. Had one in mine.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
Old 10-18-2002, 12:58 PM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jim: as always, check out Enzo's bracket in the Finish Line catalog. Installs easy and works great. Open the trunk it locks open and has a simple release to close. What would we do without the good folks at Finish Line!
Jim
OhioCobraClub.com
Old 10-19-2002, 08:39 AM
jams's Avatar
Anyone have pictures of the Finish line Bracket installed?
Thanks for the tips.
Jim
Old 11-23-2002, 08:48 PM
i am not sure how much trunk space you need but i just install a gas strut on mine. i will give you the part number and the run down, took about 30 min. and works great helps open when your over half way and when you close just lower and then drop. you could use a stronger one but i didnt find one with the swivel end i liked . one mightylift part and 2 screws. here we go. mightylift from autozone. 19.99 each. model number 95263 and 95273 the 95263 is for the rear. it has a small 2 hole bracket i attach at the base of the trunk toward the back. and then drill one small hole in the truck arrm on the left side. works great. you will loose a little of the left side of the trunk do to bar reaching across but is still get chairs in with out a problem . i used the other for the front. just drill in the front crossmember and placed a small L brack off of the front hinge drill and hole on each end . use the supplied bolt /cap ends and again you have a nice gas strut lift . the front will lift the hood once you are about 1/2 of the way up. email if you have questions or want pics. was fun and to easy. PS just make sure the length of the hood open is where the strut is at max extension dont want to put any undue stress on the fiberglass.
Well officer.. It was like this.
