Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 06-11-2004, 10:26 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Sensative Faria Temp Guage?
I have my temp sensor in the manifold just in front of the thermostat. Today on my test drive, I noticed that if the far got bouncy, the guage would bounce between 200 and 250. If I came to a stop, it seemed to hover at 200. I am thinking that it is just bouncing, but want to make sure something is not wrong that is causing it to suddenly read a correct temp over 250!
Also, my gas guage must be reversed. I filled the tank, and it is pegged below empty.
Tom
Old 06-15-2004, 07:14 AM
Cobra Make, Engine: B&B #281, 351w from The Engine Factory, and a Ford AOD from TCI
Default gas gauge problem
Had the same problem with gas gauge. Here is the thread that help me fix mine.
Gas Gauge Problem
Check your ground on the temp gauge may be a loose connection somewhere.
