Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-04-2004, 04:29 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Upper Radiator Hose revisited
Well, the car is 95% done, and has 450 miles on it, and I am thinking about modifications. Has anyone used the cool flex or other polished hose with a 302? In my setup, the upper radiator hose comes out right in front of the alternator. Without a sharp 90 degree bend that I cannot get with the metal flex hose, I am not able to get around the alternator. I thought about mounting the alternator in a low position, however, that does not work with the frame rail being right there.
Tom
Old 08-04-2004, 04:30 PM
jams's Avatar
Cobra Make, Engine: B & B
I don't have the same setup but here is a thought.... would a different thermostat housing work? Summit has a few different varieties 45, 90 and you can turn them in any direction you need to. I went through two before I found the right one. I also used Summit's version of cool flex. It works and looks great but it does cost a fortune!!!
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 08-04-2004, 07:44 PM
It is actually the input to the radiator that is the problem.
Old 05-09-2005, 07:49 PM
Cobra Make, Engine: B&B, 351c
I have been using the cool-flex hose. Very happy with it. No leaks.
Old 05-09-2005, 09:20 PM
How do you have yours routed? What alternator bracket are you using?
Old 05-11-2005, 03:28 PM
Sorry OhBuoy--Missed that you have a 302. I don't have the same set up.
