Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 12-17-2004, 02:44 PM
wesjr's Avatar
Cobra Make, Engine: 2007 FFR 4.6L Supercharger | 5 speed
Default Wake Up Call
SO I drive my cobra to a Xmas party lastnight, a good 25miles each way, I return home via the freeway, doing 75+
I get off at my exit, sitting in the turn lane, light turns green I go and as I turn the passager side lower ball joint seperates....
No damage other than my pride tho....
So in closing check those nuts and cotter pins =)
Old 12-19-2004, 11:47 AM
GREENSNAKE's Avatar
Default Ball Joint
Hey Wes! have you taken a good look at the balljoint?What seem to be the cause ?
Old 12-19-2004, 11:56 AM
wesjr's Avatar
the threads were stripped pretty bad, I assume it was viberation that caused it to loosen, I spent friday going thru all the nuts/bolts...
I found 1 or 2 more nuts that had came loose, replaced em w/ aircraft nuts.
I pick up a new ball joint for $49, got it same day so was not too bad.
