Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-03-2005, 11:33 AM
Cobra Make, Engine: B&B,351/385hp,Silver/Black stripes
Default Power brakes
Is anyone using a power booster on their B&B? If so what make and model? Did you utilize the existing master cylinder. I would like to get a little bit more braking power, I have 11" camaro disks up front and standard disks on the back ( whatever was stock on an 8.8 rear. Unfortunately I did not build the car so am not totlly sure of all parts on it.
Old 02-03-2005, 01:08 PM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default Power Brakes
Hi,
I built an A&C and originally had manual brakes (separate Wilwoods with a balance bar) but I wanted more braking power and swapped for a boosted unit.
Problem I had was sufficient clearance between the footbox and the inner fender. I used a unit from a 1974 Vette which A&C had recommended. Only thing I had to do was cut a relief in the inner fender for the front of the master cylinder. The unit provided unbelievable stopping ability. I am now in the process of covering the relief hole with fiberglass building a recess for the MC.
Also, the '74 Vette has an integral proportioning valve eliminating the need for an in-line valve.
I don't know what kind of room you have for the swap, but I thought this might give you some ideas.
Some guys also have used a Gran National Powermaster unit that uses an electric remote vacuum booster.
Tony
Old 02-05-2005, 09:33 AM
TonyMadrid's Avatar
Default Correction
Steve,
I mistakenly wrote that I used a '74 Vette MC; it is an '84 Vette MC.
Old 02-05-2005, 11:42 PM
Cobra Make, Engine: B&B non-donor, 496 Genesis SO (608 HPwith 9.4:1 CR), Tremec TKO, Currier 8.8
How much did you use from the '84 Vette?
Check one or more:
_____ Booster?
_____ Master cylinder?
_____ Pedal?
Brian
Old 02-07-2005, 06:07 AM
TonyMadrid's Avatar
I only used the booster and MC. I used a pedal from a Mustang II and I attached it to the footbax provided with the A&C kit. I had to reposition the hole that connects the pedal to the MC pushrod to accommodate the longer pushrod and still was able to keep the correct pedal ratio.
