03-22-2005, 09:44 AM
IL
Cobra Make, Engine: B&B Kit built in 2000, 514CID Big Block Ford with Richmond 5sp and Ford rear
Just bought a used B&B and have lots of questions
Hello everyone!
I just picked up a red and white2000 B&B Cobra with a 514 Crate motor and Richmond 5sp and I had a some questions.
The car has less than 300 miles on it, and hasnt been driven in the last year. I want to do some maintenance but I don't have any specs on the car.
1) What kind of brakes are used on these cars?
2) Can I replace the Radiator with something more recent?
3) Can I get another oilpan to fit under this car with more than 3inches of ground clearance under it?
Thanks in advance for your help!
Ever
03-22-2005, 09:56 AM
OK
I have a 2000 B&B with a 427 and to answer some of your questions:
Brakes: Fronts are probably GM Metric(78-80 Monte Carlo), Backs 87 Lincoln Mk VII as is the axel if it is a solid 8.8. I switched mine to dual piston Wildwoods.
I had a custom radiator made for mine by Arts Radiator in New Jersey ($450).
I am running a Canton Road Race oil pan ($350) and I have between 3 1/2 and 4 " of clearance. Hasn't been a problem yet.
Clois
"Let's roll"
"Be part of Something Good
03-22-2005, 04:53 PM
IL
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Yet another B&B owner in the area, awesome! I am trying to get together a purchase for ROn Davis Radiators with built in fans. Where was the car from?
03-22-2005, 06:39 PM
IL
Down south a bit
I bought the car from its original owner who lived in Decatur. I actually just stumbled on the car. I was working in Decatur and picked up one of those free "Sell you car" papers that's in the hotel lobby where I was staying.
Right there on the second to last page was this guys B&B cobra. It had only about 300 miles and he said that it doesn't get driven anymore. The guy wanted to get rid of it to start a business. So over the last month as I was travelling there I kept talking him down in price until I decided to get a truck, trailer and a cashiers check and take her home.
The guy took pretty good care of it, but it still has some paint chips and the motor is kind of dirty. But nothing a little elbow grease won't take care of.
The kit looks like it was designed with quality in mind, but it's definately a driver's car. Not a trailer queen. Which is good cause what's the point in having this nice of a car and not driving it.
Anyway...it's good to see that there are other B&B kits up here. I want to do some comparisons with other kits. I think there are still some improvements I would like to make, likea new Radiator, Brakes, maybe some body and interior work, but she is fine for now.
I hope to make the April 9th meeting. As long as I am not on the road working, I should make it.
Ever
03-22-2005, 06:52 PM
IL
Radiator question
The rad in my Cobra look pretty wimpy and the other day when I took it for a spin the temp hovered around 200. I don't know much about Ford Big Blocks so I didn't know if that was normal. the Big Block chevy in my '23 sits around the same temp...but she hates to be that hot.
Do you got a link to that radiator you are trying to buy? Also does it fit all the B&B kits or do I have to make brackets and such.
Ever
03-27-2005, 06:10 PM
Cobra Make, Engine: BDR, 351/408 stroker - TKO 600
I am in the process of having Ron Davis build a readiator for me as well. I have a BDR that the radiator appears to be a bit wimpy for my liking. I have an advantage. during delivery the radiator was damaged so I have the old to send to Ron Davis as a moch up with modifications in mind. Talk to Dwayne he'll get you setup
03-27-2005, 08:11 PM
IL
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Hey oncebitten,
I'll have pretty much the same motor as you and was wondering what you ment by wimpy. I will have a 180 degree thermo in mine. I figured that should be fine. Do you think its the fan and rad or just the rad?
Sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
03-27-2005, 08:24 PM
IL
I say wimpy but it might be that I just don't know how hot a big block ford should run. My big block chevy likes running around 185-190. I took the cobra out for a spin when it was 40 degrees and she ran up to 200-205 and I just thought that was a little high. I don't know if it has a thermostat in it , I have to start taking a more thorough look at the mechanicals, I just haven't had time.
Maybe BBF's like to run at that temp? I was just expecting that in that kind of weather that it would have run a bit cooler so I thought that it probably was the rad, since I had the same problem with by BBC. I have a new Walker Z rad for my BBC which should solve the problem with my BBC.
I just don't know if the Cobra should run that hot. It has dual electric fans in front of the rad. I thought that the fans should be behind the rad and not in front of it.
These are just opinions though, since I am new to this car and to the setup in it. I suppose that I will learn as I go along.
Thanks for the help and I hope to see you at the meeting.
Ever
