Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 05-12-2005, 04:23 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Anyone using low mount alternator bracket?
Is anyone using the equivelant of the March alternator bracket that hangs the alternator low? I tried this in the past, and it seemed like there was not enough clearance to the frame rail. I would really like to run this setup if possible, as it would give a better path for the upper radiator hose, and might allow use of a bracket without modifying it.
Tom
Old 05-12-2005, 05:05 AM
Cobra Make, Engine: B&B Manufacturing,351 SVO stroker from Bennett Racing
Tom:
I use an upper mount but it has a spacer for it. I agree the hose for the radiator is a little wierd looking and seems that you would be able to run it a better way... but have not found it yet.
J.A.
Old 05-12-2005, 10:43 AM
Cobra Make, Engine: ERA234 427s/o toploader
Tom,
I am currently using the low mount alternator bracket on my A&C with 347 sb and it is close to the frame but have had no problems. On my particular frame I could get more room if needed by using a shorter belt. Your frame is very close to mine from what I've seen. Also I'm using an early waterpump ( pass. side bottom hose). Boy that tensioner March uses is the cats a$$.
Toby
.....oil dry magnate!
Old 05-12-2005, 11:07 AM
REDSC400's Avatar
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
On my ERA 427 S/C (#375), the low mount alternator bracket does not fit with my big block 428. The chasis rail is "just" in the way. It also puts the alternator just in front of, and thus closer to, the headers.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
Old 05-12-2005, 06:56 PM
I am using a March setup with my 351W and though the alt. comes very close to the frame, it has not presented any problems at all. The 351 setup is a little different than the 302.
I will get some photos to you if you want, but I am out of town until the weekend.
