Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 08-14-2005, 05:45 PM
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
Default Rack n pinion
I instaling my stearing up grade on my B&B and have washers and spacers with the bolts to conect it to the frame ok where in the hell do they go, photos or a diagram would be nice I just want to do it once.
Thanks, Guys
Old 08-15-2005, 12:30 AM
Cobra Make, Engine: Superformance Brock Coupe
If you want to do it right..it's going to take more than just bolting the rack in place. Even a few thousanths of an inch in height , off the mounting surface (assuming it's in the right place!) can affect the bump-steer. You'll need to set the car's ride height first, put it on blocks at that height and then remove the spring and shock, so the suspension can be run through its full travel and THEN measure the bump-steer with a dial indicator. You'll see that rack positon is VERY critical. Badger
Old 08-15-2005, 12:30 PM
jams's Avatar
Cobra Make, Engine: B & B
All I have is one picture. I will add it to my gallery any min.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Display Modes
